Hard to steer with wide tires
Old Mar 23, 2011 | 11:57 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I did put 275/40ZR17 and Ronal R15 (17x9.5) on my TA all around. It has new bearings and I am waiting to get new steering parts.
When I drive it the steering is really hard, its seems that I am alwais fighting the steering wheel. I have heard other talk about the same experiance after the put big tires at front.
Is there something I can do to make it better (other than getting narrow tires) or should I just get used to it?
Old Mar 23, 2011 | 12:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Hard to steer with wide tires
Probably has a lot to do with the backspace/offset of the rims.
Old Mar 23, 2011 | 12:35 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You can play with the geometry some but whatever you do it's going to be harder than with narrower tires.
Old Mar 23, 2011 | 01:34 PM
Guest
Guest
Posts: n/a
{Thinking to myself, wow- how do I respond to this. I can type an easy answer that will be greatly misinterpeted- thats what makes this hard)
So many things can contribute to this hard steering.
Let me just first state the obvious, you are putting wheels and tires on the car that where not engineered for the car. but that might not be your problem.
I will ask you some questions-
When you say "hard to steer", do you mean the steering wheel effort takes alot of muscle to turn? Do you mean the car is hard to control and keep straight? Do you mean it turns too easy but is hard to unturn the wheel to straighten out the car? Are you refering to turning the steering wheel when the car is stopped, whenthe car is going say 30mph? when the car is going say 65mph?
Is the wheel jerky like something is binding as you putsterring effort into the wheel that maybe did not exist with thinner front tires (could be a bad steering box that now is showing wear when more force is applied)
So many potential problem. Could even be worn balljoints and tierods binding and changing steeing imputs and causing the wheels to fight eachother and fight toe settings. Is the front of the car raising or lowering as you go forward compared to reversing and is the effort noticibly changing in the change of directions- could be partially alignment.
More than likely its several problems combined- like worn parts and wrong alignment settings.
Old Mar 23, 2011 | 06:14 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Originally Posted by Vetruck
...When you say "hard to steer", ......Do you mean the car is hard to control and keep straight?
Thats it, the power steering is working, it has new balljoints, new bearings, new brakes, wonderbar, new Bilstein shocks, not lowered. I am waiting for the rest of the steering parts to arrive from the USA.
Thank you for your answear, it did help, now I know where to start looking It feels like the road is controlling the steering wheel and thats not good (I havent taken the car to some speed yet, just driving undir 25 mph).
Old Mar 23, 2011 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
that happens when you install wider front wheels.
have you had the front end apart? does the car need a alignment?
Old Mar 24, 2011 | 04:06 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I havent but I am planning put lowering springs (1") up front and I am waiting for the steering parts to arrive, after that I will take it to a shop to have it alignmented.
Old Mar 24, 2011 | 04:27 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i went from a 225 to a 245 an mine steered different .
Old Mar 24, 2011 | 07:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i went from a 215 to a 245 and noticed nothing...
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
mustangman65_79
Aug 9, 2015 03:00 AM
