Sway Bar end links
Old Mar 31, 2011 | 12:24 PM
jwoodworth90's Avatar
Sway Bar end links
I have an 85 iroc that and was wondering what size sway bar end links i needed?
Old Mar 31, 2011 | 02:31 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: Sway Bar end links
IIRC, all of the swaybar endlinks on the thirdgens are the same... year to year and both front and rear.
They're pretty cheap - Rubber ones are like $4 per side, Poly ones are like $20 for both sides.
Old Mar 31, 2011 | 03:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
And both rubber and poly (Energy Suspension) available on the shelf at autozone.
Old Mar 31, 2011 | 09:19 PM
They have different lengths though like 4 1/4 in or /2 3/8 in.... i got the sway bar with no links so i can measure the old ones.
Old Apr 1, 2011 | 06:37 AM
Stock, they were something like 3½" - 3¾".
Most lowered cars need something less, like 2½" or so. Most old cars with sagging springs, as yours is unless you've changed them recently, are like this.
Don't over-think it. It doesn't much matter. Get whatever length makes you sway bar closest to parallel to the ground, with the car sitting normally.
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
