Floating
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Floating
What have you guys done to reduce the "floating" of your cars? When I get on mine it feels like I'm in a boat!
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: Floating
Floating at speed? A good place to start is the struts and shocks. What tire pressure do you run?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Floating
all cars will float a bit until enough water gets in them, then they sink.... open the doors, it will sink faster
shocks and struts, good ones, not Gabriel's or monros's, cheep house brand ones either
Re: Floating
Make sure your sway bar endlinks and mount bushings are in good shape too. Upgrading those to poly examples is always a simple, cheap upgrade that helps stabilize things.
Axle/Gears: 273
Re: Floating
That's where I was goona start with the shocks... Does the sway bar have anything to do with it? I know it feels as though I'm driving a 70's or 80's type Caprice... I hate the way it rises and then when I shift it comes down.....
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Re: Floating
checkout the bushes and front top mounts as well. As rubber degrades it allows for more movement which can result in a vague and generally sloppy feeling car
A quick note I've got gabriel shocks on my GTA (previous owner) - I've put some bearing top mounts, choice poly bushes and a strut brace and I must say the car feels tight. It does bounce about a little which the konis I have sitting should cure but it turns sharp and the ride is firm - I guess my point is that these cars didn't 'float' when they were new so if you just wanna cure this and get it back to factory spec - you may not need to fork out the coin for some konis
good luck - hope you sort it>>
good luck - hope you sort it>> Thread
Springster
Sep 13, 2015 01:38 PM
