Spohn Adj TQ Arm Problem
Old Apr 27, 2011 | 12:23 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I put the SATA on my 89 Firebird; I run a WCT5, stock x-member, stock steel shaft, Strange 12 bolt, poly bushings everywhere. I was able to get the true pinion angle set a few times (-1). However, it measures fine after getting it set, I drive it and the TPA moves to a lower number. I readjust it and use the blue loctite and it still cannot hold a setting.
Specifically, my readings from DS (driveshaft) & PA (pinion angle):
initial DS1, PA 2 (-1), drove it..
DS 3, PA 4 (-1), still ok, drove it...
DS 3, PA 5 (-2), readjusted to -1, drove it...
DS 2, PA 5 (-3), car sits in the garage waiting for a solution
Like I said, I used the loctite, loosened and tightend the bolts on the side, everything's tight. I called Spohn a number of times, and they have been very gracious (Thank You Megan), even had her ask Steve Spohn to which he replied that he'd never seen this before and thus had no answer. Anyone run into this problem before or can think of something I can look at?
Thanks to all,
Eric
(this posted in both Transmission & Suspension forums to get as many answers as possible)
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Irocguy01
Sep 28, 2015 02:03 PM
Dialed_In
Aug 20, 2015 01:45 PM
