Replacement rag joint
Old May 20, 2011 | 08:56 PM
Vicinity2's Avatar
I'm trying to find a replacement rag joint for an IROC box.
Does this rag joint fit?
http://cgi.ebay.com/ebaymotors/1970-...Q5fAccessories
Someone told me Larescorp makes a rag joint that fits that box, I'm unsure of which one it was.
Old May 21, 2011 | 07:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Replacement rag joint
Welcome to TGO, Vicinity. You'll find that there aren't too many questions that haven't been asked and answered on site, so a search will generally provide the info you're looking. Check the following link for an AutoZone replacement. Some members have replaced the entire business with an Astro Van or Jeep shaft. Good luck with your project.
https://www.thirdgen.org/forums/susp...ment-gory.html
JamesC
Old May 21, 2011 | 08:17 AM
Vicinity2's Avatar
Yeah, I've been searching but I couldn't find a part number or a link that wasn't dead.
Thanks.
Old May 21, 2011 | 08:21 AM
JamesC's Avatar
)(&(*^*^%$! Check my post above--where I neglected to paste in the link.
JamesC
Old May 21, 2011 | 08:39 AM
Vicinity2's Avatar
I believe he used a rebuild kit for that?
Only issue is I don't have a third gen, I'm swapping the box into a 68, so I have nothing to work with. I need the entire part (not just the literal joint).
I really just need the size and spline count of the shaft that comes up from the box (steering shaft?).
EDIT: I believe it's 15 spline. Just have no confirmation.
Old May 21, 2011 | 08:46 AM
JamesC's Avatar
Since TGO is dedicated to 82-92 F-bodies, you may be better served to check out other sides, such as the following:
http://www.camaroz28.com/forums/
JamesC
Old May 21, 2011 | 08:51 AM
Vicinity2's Avatar
I've got a thread on Camaros.net, but I thought I'd check here to see if anyone knew where to get a complete rag joint for a 3rd gen box (the 3rd gen RJ will swap to the 1st gen column).
Old May 21, 2011 | 08:56 AM
JamesC's Avatar
Maybe the entire piece?
http://cgi.ebay.com/ebaymotors/Fireb...#ht_1187wt_923
JamesC
Old May 22, 2011 | 09:12 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I got a flaming river DD shaft with solid ujoints on both ends and what a difference in feel compared to the rag joint. You're better off getting solid joints in my opinion.. Been driving for 2 weeks with it this way and I love it.
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
