Front suspension 1986 Camaro
Old May 23, 2011 | 06:40 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
I went to get my tires rotated and aligned but they came back with bad news.
I supposely need to replace my ball bearings, my struts and strut mounts.
I'm guessing either time or this last winter killed it haha(hit curb a few times).
Now why would you need to replace the strut mounts? They look like solid plates dunno how they figured they needed replaced. How do you tell? Is it just a saftey meaure or something?
And would you reccomend that I do all that myself? Is it that complicated? I've looked around and doesn't seem that bad. Anyway I need to get something done, the tires done even have 10k on them and the right one has half the tread as every other tire has. It's freaking ridiculous.
Also looked up the parts. Found them all cheaper than shop listed them for. Pretty funny huh?
Old May 23, 2011 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front suspension 1986 Camaro
bajj JOINTS, not bearings.
strut mounts have a rubber bushing in them, that can be torn or otherwise fail. if you take the plastic cap off, you can see it, and if its obviously cracked or broken, it will be pretty apparent. Its a 25 years old car, chances are they are original, might as well change them.
balljoints need to be pressed in and out, you can do it with loner tools from autozone or such, but you really need air tools. Same with the struts, the bolts to the spindle are really really tight, and doing them be hand will be really tough. But not really a hdr job with the right tools. Stuts mounts are simple, especially if you have already taken the strut off.
Dont go for the cheap struts, monroe, gabriel, ect are all crap. Spend money here on good parts. You can always look do a search here and see what people recommend, buy the parts yourself, and have the shop install them.
Shops will ALWAYS make up parts, it normal. Just depends on what they are selling you. if they are selling you 20 dollar POS parts for 200bux, thats a rippoff, but a markup is normal (they have to make money to stay in business)
My opinion, its worth the investment to buy tools (good tools) and learn to do work like this yourself, you will save a crap-ton of money in the long run.
this sticky has a lot of good info and pictures.
https://www.thirdgen.org/forums/susp...nsion-how.html
Old Jun 30, 2011 | 07:19 PM
Engine: 350 SWAP
Axle/Gears: Stock
Here's what I ordered;
2x KYB 236001 GR-2 Struts
KYB SM5027 Strut Mount
KYB SM5028 Strut Mount
& some lower ball joints, which I got a great deal on, both lower bj for 20$
Yeah some people have bad things to say about them but there are also some good things.
Pretty much OEM which is cool with me. I'm on a college kid budget with no job so anyway.
Now I was thinking about replacing my spring coils too, at-least in the front.
But I don't want to do that unless it actually needs it. Where can I find proper ride height to check them out? I can't find it anywhere...Maybe I'm over thinking it.
Anyway of testing them as-well?
Hypothetically speaking the spring coils are alittle worn out- could that put great wear on my new struts? The car as it sits looks fine. It would be nice to find the factory height specs.
Old Jun 30, 2011 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
factory height is hard, but its somewhere around 27.5 28" or so? ground to fender with a 25.7" tire. but it varies so much. If you liek where it sits, leave it alone.
Old Jun 30, 2011 | 07:32 PM
Engine: 350 SWAP
Axle/Gears: Stock
Do you know whether or not it will affect the new struts if worn? Not sure if they are original spring coils or not
Old Jun 30, 2011 | 07:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
probably not, unless the car is sitting really low (stupid low) because the springs are totally shot or broken, then yes, the shorter length of the springs could cause issues tot he shocks in the long term, but without knowing anything else, its hard to say.
Old Jun 30, 2011 | 07:45 PM
Engine: 350 SWAP
Axle/Gears: Stock
It doesn't sit bad from just looking but I'll measure
Old Jun 30, 2011 | 07:56 PM
The strut mounts allow the struts to turn, as you steer the car. They have a bearing in there and it's mounted IIRC in a blob of rubber spooge. Both the bearing can go bad in ways that bearings typically do, and the spooge can disintegrate. Those are the reasons why they eventually need renewal.
Old Jun 30, 2011 | 08:00 PM
Engine: 350 SWAP
Axle/Gears: Stock
Yeah? Hmmm Well I got new strut mounts as well
Old Jul 10, 2011 | 08:43 PM
Engine: 350 SWAP
Axle/Gears: Stock
Today I realized why I not only love this car but ****ing hate it.
I've been on it all day long. I'm getting sick and tired of the bullshit
I've read through two of my manuals and this forum how to and still cannot get the freaking ball joint off. Took along time to get the freaking strut off and then this crap.
I cannot get the rotor/spindle off of the ball joint. It simple refuses. I'm guessing the ball joint comes up through the bottom, am I correct? Not through the top press below? Or am I mixed up????
Attached images of the garbage.
Attached Thumbnails Front suspension 1986 Camaro-imag1358.jpg   Front suspension 1986 Camaro-imag1360.jpg
Old Jul 10, 2011 | 09:34 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I like to pull the rotor to get the struts nuts and bolts to me its easier plus gives you a chance to re-pack the wheel bearings or replace the bearings and races. or rotors whatever.
To get the spindle to come off the ball joint -
I like to use this.
If i plan on replacing parts and feel reckless i use this
Old Jul 10, 2011 | 09:56 PM
Engine: 350 SWAP
Axle/Gears: Stock
I like to use this.
How does that first tool work? I'm trying to imagine it but cant.
The second one I imagine you place under the spidle and pry?
I'd assume you could use a sledge hammer on the balljoint threaded side?
Also, I already replaced my rotors and bearings not long ago that's why I didn't want to take off the rotor.
Old Jul 10, 2011 | 10:16 PM
FueledSoul's Avatar
Your pushing the ball joint stud out of the spindle. The tools lags rests on the bottom base of the spindle as you turn the threaded rod down onto the top of the ball joint stud it puts pressure on it and forces/pushes it out . Just like removing a steering wheel or harmonic balancer... very simple. The pickle fork is a more cruel way of getting the stud to separate it self from the spindle it works fine if you want to tear up boots and possibly **** up threads or damage parts but if your already plan to replace them then fine. you put it between the spindle and ball joint and use a hammer, sledge whatever. Your basically using a wedge that's creating pressure on both the ball joint/lower control arm and bottom spindle each blow of the hammer drives it deeper and creates more pressure between the two eventually splinting them apart same principal as a wood wedge. You can still take the rotors off with out repacking them if your careful
Old Jul 10, 2011 | 10:21 PM
Engine: 350 SWAP
Axle/Gears: Stock
Thanks man, that helps a alot
Old Jul 10, 2011 | 10:22 PM
FueledSoul's Avatar
Your welcome, not a problem!
Old Jul 10, 2011 | 10:32 PM
Engine: 350 SWAP
Axle/Gears: Stock
Lets hope I get it done tomorrow! haha...
I'll update then!
Old Jul 11, 2011 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Don't be surprised when the strut mount retainers from your 86 won't fit the above mounts. Check the following link for more info:
https://www.thirdgen.org/forums/susp...elp-quick.html
JamesC
Old Jul 11, 2011 | 09:39 PM
Engine: 350 SWAP
Axle/Gears: Stock
JamesC
Fits perfectly bro.
Also that balljoint press is the worst tool ever to try and press the joints back in. It would absolutely not press the balljoint in straight. No matter how slowly and carefully you went. It always went in crooked.
We are doing a different method tomorrow. It worked getting it out but that doesn't cut it.
Old Jul 12, 2011 | 06:04 AM
JamesC's Avatar
Fits perfectly bro.
GM made two versions of the retainers, 82-86 and 87-92. The two aren't interchangeable as demonstrated in the link I provide above. Since after market mounts are based on the 87+ mounts, your perfect fit is interesting (perhaps your car was late enough in the model year to have been equipped with the later type).
http://www.spohn.net/shop/1982-1992-...-92-Style.html
JamesC
Old Jul 12, 2011 | 01:38 PM
Engine: 350 SWAP
Axle/Gears: Stock
Here you go-
Old Jul 12, 2011 | 01:45 PM
JamesC's Avatar
Here you go-
So the 86 retainer fits the mount you picture above? If so, it would appear that the mounts have been redesigned to make one hole rectangular. A one-fit, 82-92, mount would be cool.
JamesC
Old Jul 12, 2011 | 07:02 PM
Engine: 350 SWAP
Axle/Gears: Stock
JamesC
=D
Attached Thumbnails Front suspension 1986 Camaro-imag1377.jpg   Front suspension 1986 Camaro-imag1379.jpg
Old Jul 12, 2011 | 08:33 PM
JamesC's Avatar
Excellent. Good to know about the redesign. Thanks for the pics.
EDIT: The above mounts are OE replacements. After market versions, such as Spohn's or HotParts, will still require the correct retainer (unless you're willing to mod a brand new piece).
JamesC
Old Jul 12, 2011 | 08:36 PM
Engine: 350 SWAP
Axle/Gears: Stock
JamesC
No problem dude
Old Jul 12, 2011 | 08:49 PM
That's actually pretty cool... there's been people who have bought those, discovered they wouldn't fit, and made that EXACT alteration to them.
Almost like that mfr has been trolling this board.
Old Jul 13, 2011 | 05:01 PM
Engine: 350 SWAP
Axle/Gears: Stock
Hahaha yeah.
I have a question now that I got my balljoint on:
I forget what order these things go in. Well except the ring which it goes around the boot. But where does the small ring go? Over or under the boot?
Anyway- success. Started going crooked but kept going and *POP*
Wooo! haha finally. I also froze the balljoint overnight.
Attached Thumbnails Front suspension 1986 Camaro-imag1390.jpg   Front suspension 1986 Camaro-imag1391.jpg
Old Jul 14, 2011 | 11:44 PM
Engine: 350 SWAP
Axle/Gears: Stock
I got one side done. I'm not totally sure on that boot placement- was I suppose to cut the rest off? Or does it matter?
I'm done with that side like I said besides torqing the castle nut and placing the pin in. It's pretty tight but I want to be correct. Just trying to get the other balljoint out now. I will finish the second side in the morning.
If I wandered off just let me know. The balljoints seem pre-greased but I'd guess just to put more in it anyway soon.
The ring unnecessary?
Attached Thumbnails Front suspension 1986 Camaro-imag1396.jpg   Front suspension 1986 Camaro-imag1398.jpg
Old Jul 15, 2011 | 12:41 AM
Engine: 350 SWAP
Axle/Gears: Stock
Also what kind of dust covers should I get? I can't seem to find anything.
I didn't end up taking off the originals and the mounts are so stuck it seems impossible to get to the old covers...
I guess I could look at it again.
Old Jul 17, 2011 | 01:28 PM
Engine: 350 SWAP
Axle/Gears: Stock
Bump, I could use some help on the covers and some replies on the balljoint boot. Is that going to work?
Old Jul 24, 2011 | 07:56 PM
Engine: 350 SWAP
Axle/Gears: Stock
Okay well its all done, haven't got an alignment yet but finally done and greased haha...
Never want to do that again...
Though I do have a slight pop, I think its somewhere else. Check it out, still not totally sure. Happens in turning. I'll look at it later I suppose.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
