front coil spring diameters needed asap!
Old Jun 15, 2011 | 06:10 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
if anyone has a set not installed, could you get me an OD and ID (front springs only) measurement real quick? I am working on machining a few 1/4" thick spacers and dont want to have to take my front end apart just to measure
Thanks in advance
Old Jun 15, 2011 | 06:17 PM
RyanEricW's Avatar
Re: front coil spring diameters needed asap!
Front inner diameter should be 4.08-4.09" for all f-bodies. With spring thicknesses ranging from 0.656-0.765".
Outer diameter should be between 5.392"-5.62".
I'm using my data source to calculate these numbers. If anyone could follow up, that'd be great =)
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
Thanks!
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
