Vibration at Highway Speed
Old Jun 16, 2011 | 05:36 PM
fourwheelin7's Avatar
Car: 1986 Chevy Camaro IROC-Z28
Engine: 305 V-8
I recently purchased a 1986 IROC-Z 28 with 52,000 miles on her. So far I've replaced the front struts and rear shocks, front end alignment and brand new tires all the way around. At interstate speeds 65 mph plus get a vibration coming from front end some where, kinda of puzzled of what this could be, anybodybwith ideas?
Old Jun 16, 2011 | 09:43 PM
V8ReiMeR88MaRo's Avatar
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Re: Vibration at Highway Speed
Wheels could be out of balance. Mine did it above 55. Could try that. Take your car in to a good reputable tire shop and see if they will run your front tires on they're balancing machine.
-V8R
Old Jun 16, 2011 | 11:12 PM
Engine: 305 V-8
Just had new tires and balancing done! Really thought that was the problem but nope
Old Jun 17, 2011 | 06:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Common issue, it is the driveshaft. Can either get a new aluminum one for a '98-'02 Camaro/Firebird with the V8. Or get a new one from a shop such as Denny's.
RBob.
Old Jun 17, 2011 | 11:16 AM
Engine: 305 V-8
Thanks RBob would you recommend buying new or used? Browsed through eBay shortly saw a lot of used ones on there. And any other good places besides Denny's for driveshafts?
Old Jun 17, 2011 | 12:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Big QUESTION: Did you have this Vibration before the new tires???? If not rebalance and rotate the tires.
Old Jun 17, 2011 | 12:57 PM
Engine: 305 V-8
Yes did have the vibration prior to new tires, one reason I replaced the old tires, had take it in to get old ones balanced and found the front tires were out of round from sitting to long, put 800 miles on them with no luck still vibrating, so replaced with news tires and that took care of some of the vibration but still get it especially anything over 60 mph, below 60 mph drives great.
Old Jun 17, 2011 | 07:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For stuff like this I prefer new. A drive shaft is a wear item, and can also be stressed and fatigued. If you run across a used one and it is hands on, then check it. Examine for dents and/or gouges on the shaft.
Then move the u-joints and feel for notches. If it feels notch-y, then they are worn. The ears can also spread causing end play in the joints. So check the side-to-side play too.
There are many drive shaft companies out there. Inland Empire (Inland Imperial??) is another that comes to mind.
I've used truck re-builders to build a drive shaft. But they are not always balanced enough for high speed work. Hence the purchase of new drive shafts from companies that build them for hi-po use.
RBob.
Old Jun 18, 2011 | 03:01 AM
Engine: 305 V-8
Old Jun 18, 2011 | 03:02 AM
Engine: 305 V-8
Sounds like good advice to stick with new! Thanks for the info sir, much appreciated!
Old Jun 18, 2011 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I once sold 60+ JG1 alum shafts, the so-called 1LE version. I never had a customer complain for any reason (I always checked for dents, gouges, lose of balance weights and so on and advised installing new U-joints). I've been running one that I purchased used for a number of years.
That said, you can't go wrong with new, though the cost may be prohibitive.
JamesC
Old Jun 18, 2011 | 12:22 PM
Engine: 305 V-8
Thanks James
Bubbajones_ya
Jul 6, 2024 08:32 PM
sac92transam
Oct 7, 2015 02:31 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
InfinityShade
Sep 18, 2015 08:32 PM
