installing trick front springs
Old Jun 23, 2011 | 12:04 AM
cannan5's Avatar
Car: 86 camaro
Engine: big block
Transmission: glide
I need some help. I bought a set of moroso trick front springs for my 86. I am having difficulties installing them. 1st question. If any one has installed these, which way does the pig tail side go? Into the a arm or upper pocket? 2nd question. Which spring compressor to use? I have the one that goes on the inside of the coil and cant seem to get the coil in without the shaft hitting at the top of the pocket. Do I need to use the one that you use for coil over struts? someone please help.
Old Jun 23, 2011 | 12:24 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: installing trick front springs
1. Pig tail goes down on all front springs
2. I've always put in lowering springs & never used ANY compressor, so I'm of no help there.
Old Jun 23, 2011 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Use a pipe nipple like the one in post #5 of the following post:
https://www.thirdgen.org/forums/susp...nt-spring.html
JamesC
Old Jun 23, 2011 | 09:33 PM
cannan5's Avatar
Car: 86 camaro
Engine: big block
Transmission: glide
thanks for all those who helped. FINALLY got them in.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
