Steering advice needed. Car hard to keep in the lane
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
My car wonders allover the lane at highway speeds. Lots of play in the steering. Feels like I'm driving a boat. I can move the steering wheel a few inches side to side without moving the wheels. Just wondering where to start looking for trouble.
Re: Steering advice needed. Car hard to keep in the lane
With that much play it is time to replace all the front steering parts.
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
verify tire pressure no not laugh
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check the rag joints as well.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Also check the area around your steering box for cracks, and if you have a steering brace (aka wonderbar). If there are cracks then that could cause unstable steering.
Also, your alignment could be out of whack too. I would replace the steering items as mentioned up above and then get an alignment to see what specs your wheels are at. Camber should be equal on both sides but negative camber is better for handling on the street, same as toe ( 3/32 is a good setting for toe-in), and caster should be as much as possible but with 0.5 more on the passenger side.
Throwing parts at it is not an effective way of fixing the problem.
Do this; park car, pop hood. Have a helper sit inside with the key in the run position so the steering wheel is unlocked but leave the car off. Have the helper slowly wiggle the steering wheel back and forth from each side of center within the range where there is play. While they do this get underhood and follow the movement down the steering shaft through the linkages out to the wheels. You will see where there is slop. It may be a combination of things. Fix the problem and get an alignment done. Problem solved.
Terrell351
Jun 13, 2021 01:13 PM
