New UMI rear suspension kit installed
Old Jun 30, 2011 | 11:31 PM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
Went down to Summit racing last weekend and bought lower control arms, panhard bar and subframe connectors. Finished installing the suspension components tonight. Still have to weld the lower control arm relocation braket. Getting it made at work perks of working at a race car manufacturer. Those will come next with the subframe connectors. As for the parts they fit great will post pics tomorrow.
Old Jul 1, 2011 | 08:28 PM
UMI Performance's Avatar
Re: New UMI rear suspension kit installed
Great to hear! I look forward to seeing the pictures. Have a great 4th!
Old Jul 4, 2011 | 12:45 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
What type of difference does the lower control arm upgrade give?
i have an edlbrock panhard rod,cus mine was bent.
Old Jul 4, 2011 | 01:35 PM
Car: 1987 Camaro
Axle/Gears: 4.56
Control arms help prevent some wheel hop.
Old Jul 4, 2011 | 02:08 PM
Car: 1987 Camaro
Axle/Gears: 4.56
http://s587.photobucket.com/albums/ss313/mattmerritt/
Here are the pics
Old Jul 6, 2011 | 08:28 PM
Car: 1987 Camaro
Axle/Gears: 4.56
http://i587.photobucket.com/albums/s...t/100_0826.jpg
Start of the lower control arm relocation bracket. holes and a spacer all that are left to do.
Old Jul 8, 2011 | 02:53 PM
Looks great... thanks for sharing
Old Jul 9, 2011 | 03:51 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Love to see photos of the subframe connector in place.Id like to make that my next project and really am leaning toward the UMI pieces. By the way nice support cover.
Old Jul 9, 2011 | 11:50 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Hope to have the subframe connectors installed this weekend.
Old Oct 19, 2011 | 05:43 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Nice set up. Did you install the panhard bar yourself and did you have any problems? thanks.
Old Oct 23, 2011 | 08:38 AM
Car: 1987 Camaro
Axle/Gears: 4.56
No, I didn't have any problems installing it. I did the whole install up on jack stands. The only problem I had was breaking the fasteners loose. I banged my elbow real good, hurt for a week.
Old Nov 3, 2011 | 04:50 PM
91kbell's Avatar
Would you mind giving me the dimensions of the LCARB's.
Old Nov 4, 2011 | 10:35 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I can see why you didn't have any problems, neither did I when I did mine a couple weeks ago. It went on real easy, although breaking loose the factory nuts/bolts took some doing. Luckily I didn't bang any body parts! I cleaned the bolts and nuts up on a bench grinder wire wheel to make them look pretty.
Old Nov 4, 2011 | 10:44 AM
UMI Sales's Avatar
Hey kbell. We have both bolt-in and weld-in relocation brackets. The bolt-ins are quick to install and you don't have to mess with fabrication. We take care of that for you.
Thanksgiving sale coming up.
ramey
Old Nov 5, 2011 | 02:05 PM
Car: 1987 Camaro
Axle/Gears: 4.56
Side plates are 2 3/4 x 4, and the back plate is 2 3/4 x 2 3/4. You will also need to use 1/8" plate. Need to weld a plate to the inside of the bracket to get back to the right bracket width. It is also 1/8" plate
Old Nov 5, 2011 | 10:01 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
ramey
Um, like what? I need some lca relocate brackets, and a torque arm relocate bracket would be nice, too.
Old Dec 4, 2011 | 07:33 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Got the lca brackets in this week. Got them on sell. Hoping to have them put on by the end of the day. Wish I had my freaking sub frames down at my house they would go on as well.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
