Chassis work on 89 chevy camaro rs v8
Old Jul 31, 2011 | 02:23 PM
jay173's Avatar
Ok so I need to find an idler arm, I need new engine mounts and how can I derust my springs?
Wich of these should I do first?
Old Jul 31, 2011 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Chassis work on 89 chevy camaro rs v8
get a new idler arm form the local parts store.
same place for the motor mounts, or summit jegs, ebay, classicindustries ect.
remove springs, sand off rust, paint.
Old Aug 1, 2011 | 12:35 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
If you're really going to de-rust your springs, while they're out is the perfect time to do motor mounts. That way you can drop the A-arm and actually have decent access to the motor mount bolts (PITA otherwise, but possible)
Also might just want to get new springs, as your old original ones likely sag by now. Hell, my original springs both had about 2-3" broken off in the lower spring perch, LOL
Old Aug 1, 2011 | 06:19 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I 2nd that. Once you have the springs out, best of all replace them, if this was not done before.
Might as well replace the shocks while you're at it.
And give cleaning and painting the A-arms some thought as well.
Old Sep 18, 2011 | 09:18 AM
chevy-camaro-27's Avatar
Ebay is a great place for spare parts like an idler arm but I would check with a local junkyard first.
Old Sep 18, 2011 | 09:32 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
why would you bother to pull a used, worn out idler arm out to replace a used worn out idler arm? thats just stupid. They are not that expensive new, these are not parts to pull of a junk car, replace them with new parts or dont replace them
Old Sep 18, 2011 | 09:39 AM
An idler arm only cost about $20 but you'd be surprised at how new some of the parts are on cars at junkyards and you can get parts at a fraction of the normal cost. Trust me, I've been to plenty of em so I know.
Old Sep 18, 2011 | 09:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
But each to his own.
JamesC
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
