type of spindles need for 88 iroc
Old Aug 1, 2011 | 09:03 AM
go88iroc's Avatar
Car: 1988 iroc-z red 5.0 tpi
hi i was wondering what kind of spindles do i need for my 88 camaro because ive heard for the iroc there different from just a regular z28. so do i need the spindles for a single pistion caliper or do i need one with the dual pistion caliper please i need to know as soon as poossible
Old Aug 1, 2011 | 09:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: type of spindles need for 88 iroc
All spindles are the same, though the 1LE version has the ears cut off to accommodate larger rotors and dual piston alum calipers. Your 88 would have standard rotors (10.5") and Delco-Moraine calipers (iron).
JamesC
Old Aug 1, 2011 | 09:18 AM
go88iroc's Avatar
i thought that the irocs where different?
Old Aug 1, 2011 | 10:07 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
They are not. The bearing for the IROC rotor are a little larger than the standard Camaro, but the spindle is the exact same.
Old Aug 1, 2011 | 11:01 AM
JamesC's Avatar
The standard 10.5" rotors, iron Delco-Moraine calipers, and bearings are the same for all thirdgen cars, to include IROC's. Different story for the 1LE's.
JamesC
Old Aug 1, 2011 | 03:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
JamesC
what he said
they are all the same design, later ones hada thicker casting in places, but all the attachment points are the same. Only cars with the 1le performance brakes had modified spindles and larger bearings.
your 88 has the standard spindles and bearings.
Old Aug 2, 2011 | 09:00 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
That's odd, because when I did the LS1 brake swap I didn't use my rotors for the hubs and used a non-IROC rotor. When I went to put in the wheel bearings they did not fit because I bought ones for an IROC. I went back and got a set for a standard Camaro and they fit perfect.
Old Aug 2, 2011 | 09:28 AM
JamesC's Avatar
My guess is that the counter man gave you the 1LE version, which wouldn't fit.
The A6 inner bearing is common to both the standard rotor and the 1LE.
The A3 outer bearing, which the 1LE uses, has a larger OD than the standard A34 bearing. If you had the larger bearing, you had the 1LE.
JamesC
Old Aug 3, 2011 | 10:28 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Now I cannot argue with the counter guy screwing it up. I can guarantee I did not have 1LE brakes, if I did I would not have gone to the LS1 brakes. Thanks for the insight.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
