Rod-ends for B.M.R. Adjustable Panhard Bar.
Old Aug 5, 2011 | 08:57 PM
V8ReiMeR88MaRo's Avatar
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Okay here goes, I have recently purchased a Set of Eiback Sportlines, BMR LCARB's and now I need a Panhard bar. I know BMR is one of the best on the market which is why I went with them. I have a question about them though.
On Summit Racings website. It says they do not come with the Rod-ends. Which I kinda sorta need. So I am wondering where can I pick these up so I can get all the springs, LCARBS and Panhard bar installed.
Thank you all help appreciated
-V8R
Old Aug 5, 2011 | 09:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rod-ends for B.M.R. Adjustable Panhard Bar.
the bar would be about worthless if it was just the bar with threaded ends and no rod ends for them, since you would also need spacers and adapters to fiut the stock bolts inthe rod ends......
im sure its a typo, but maybe call and ask?
as for rod ends, summit sells rod ends, as does a million other companies. they are probably 3/4"-16 left and right hand QA1 ends supplied with that bar.
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You could contact BMR & ask them, but I'd be real surprised to hear that a PHB was sold "empty"/without the rod ends.
Old Aug 5, 2011 | 09:16 PM
http://www.summitracing.com/parts/BMR-PHR002R/
Here's a like to the page. I'm more of a drivetrain guy. So this is new to me. So sorry if I'm confusing lol. :/
Old Aug 5, 2011 | 09:39 PM
Car: GTA
What you linked to is a complete version that comes with polyurethane bushings.
What you are wanting is http://www.summitracing.com/parts/BMR-MPHR003R/
Old Aug 5, 2011 | 09:57 PM
AHH I see. But wouldn't I need an adjustible one? Since my car is going to be lowered two inches and therefore it till shove my axle out towards the passenger fender?
Old Aug 5, 2011 | 10:06 PM
Car: GTA
It is adjustable. Each rod end adjusts in & out individually. But I recommend NOT going with that style. I have a UMI one & the passenger side rod end is a pain to adjust, because the bracket on the rear axle prevents a wrench from fitting in there on the rod end jam nut.
The Drivers Side adjusts just fine. But on the Passenger Side the mount bolt has to come out. Drop that bar end. Loosen the jam nut. Then twist the bar to adjust the length (Drivers Side jam nut was loosened prior to all this). Get the length you want. Tighten up the Drivers Side jam nut. Pull the Passenger Side mount bolt out. Drop the bar end. Tighten the jam nut. Reinstall the end. Reinstall the mount bolt & nut.
PITA. Not sure there is an alternative though because of the way rod ends need jam nuts on them.
Old Aug 5, 2011 | 10:15 PM
Okay. The one I posted up, is that same as you posted, just with out the rod ends?
Old Aug 5, 2011 | 10:25 PM
Car: GTA
Basically, yeah. Poly instead of rod ends & On-Car adjustable instead of needing to be half removed.
If you can find one with the rod ends welded on the ends instead of "screwed" in & held tight with jam nuts, then it could be On-Car adjustable like the Poly one you listed.
As much of a PITA as the rod ended one was to adjust, in reality you only need to do it one time so it really isn't that bad. Just not what I expected when installing it so it really pissed me off. Once it is on though, you don't need to ever touch it again until a rod end needs to be replaced. So I mighta kinda blew it out of proportion. Sorry about that. PITA, but worth it in/needed on my car.
I'm tucking 315s on a stock 3rd gen 9-bolt & have under 1/2" on both ends, from tire to inner fender, so I couldn't have even the flex in a poly bushing, so I had to run rod ends.
Old Aug 5, 2011 | 10:32 PM
Okay thanks bro. I see on the pages now. Ended up confusing myself. I got it now.
-V8R
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
