strut replacement question
Old Sep 13, 2011 | 06:59 PM
1roc89z28's Avatar
i replaced my front struts. and i just saw an thread saying you have to remove brake pads and rotor. but when i replaced my struts. i dint remove them. but everything came out alright..eventho my suspension still feels like crap...did i do it wrong?
Old Sep 13, 2011 | 07:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: strut replacement question
No need to replace brake pads or rotors to do front struts - not sure where that notion came from.
Old Sep 13, 2011 | 08:58 PM
RE849's Avatar
Car: 1991 Camaro RS
Engine: 5.0L
what brand of strut did you install?
Old Sep 14, 2011 | 12:21 PM
1roc89z28's Avatar
gabriel ultra...(even the name sounds cheap)
Old Sep 17, 2011 | 09:59 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
HOW DID YOU TRANSFER THE STRUT TOWERS TO THE NEW STRUTS ? THE SHAFT TURNS WHEN YOU TRY TO BREAK THE LOCKNUT FREE.
Old Sep 17, 2011 | 12:24 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
impact wrench works well in the garage
i've pulled a few off in the yards by using an allen wrench in the key way atop the strut rod
Old Sep 17, 2011 | 07:23 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
I think that you read that you had to remove the brake line bracket that is mounted to the strut. I just did mine not long ago. That is the only brake component I had to remove.I also replaced every thing on the front suspension except a arms and a arm bushings. What a difference!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
