Track bar brace
Old Sep 15, 2011 | 05:32 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Track bar brace
Hey All,
What is the purpose of the track bar brace and is it needed?
Paul
Old Sep 15, 2011 | 05:41 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Track bar brace
Mainly it prevents the steering box being stressed and cracking under repeated heavy loading. It's probably not really needed unless you're going to go fast round corners a lot.
Old Sep 15, 2011 | 05:45 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Re: Track bar brace
thank for the reply.
I have to cut it off to get my gas tank out, and it is tough to find part.
Paul
Old Sep 15, 2011 | 06:04 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Track bar brace
Sorry thought you meant the brace on the front. The brace at the back is a must have. Doesn't it unbolt? Don't cut it.
Old Sep 15, 2011 | 06:07 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Re: Track bar brace
Too late it is cut off. The bolt was seized couldn't get it off.
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Track bar brace
the rear panhard brace strengthens the panhard mounts, specifically the passenderside drop mount. It is a needed part, without it the passengerside mount will flex and eventually fail. It does unbolt. IF you are cutting it because the bolts are siezed, ok, you can get another from a car at the junk yard, or here is sombody is parting out a car.
Old Sep 15, 2011 | 06:09 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Re: Track bar brace
Tying to find one is difficult, it seems
Old Sep 15, 2011 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Track bar brace
its not a part that is commonly replaced, so they only pop up for sale occasionally. However there are tons of them out there. One from any 82-02 f-body will be fine.
Bubbajones_ya
Oct 25, 2015 08:01 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
