anyone usein lakewood traction bars
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
Re: anyone usein lakewood traction bars
would the rear control arms relocation brackets would they also be good for the streets not just for straight line use
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
they work just fine on the street. What i was illuding to is that lowering the back of hte control arm can help traction, but can also hurt cornering. However, this is something most people will never notice on the street, unless you are pushing the car very hard.
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
o ok thanks for the info ill start with that and see how that goes
Hello,
I haven't seen too many people having good luck with those traction bars.
What I recommend is a set of control arms and a set of relocation brackets. These items combined together will work as a lift bar would. The brackets will help to plant the tires harder into the ground.
Below I pasted two links to these items, please take a look and let me know if you have any questions.
www.umiperformance.com/2015
www.umiperformance.com/2012
Thank you!
Ryan
Thank you!
Ryan
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
thanks for the links that u posted up for them thats what im going to go with then thanks for the info on not usein lakewood traction bars that would of been money wasted if i got them and didant turn out like they should id been not happy
Thanks again,
Ryan
darwinprice
17
10-11-2015 11:51 PM
