shorter rear shock if lowered?
Old Oct 18, 2011 | 11:30 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
my rear is sitting approx. 2.5 inches lower then stock. is anyone using shorter shocks or having problems with a lowered car bottoming out the shock?
Old Oct 18, 2011 | 12:39 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: shorter rear shock if lowered?
Don't need a shorter shock for that.
Old Oct 18, 2011 | 01:16 PM
87350IROC's Avatar
Car: 87' IROC
It would be a nice to have a shorter shock that doesn't totally unload the spring at full droop. With that said, I am running stock length Koni's and they do not bottom out. The bump stop (even well cut down) will make contact first. My rear fender height is 26".
Old Oct 18, 2011 | 04:15 PM
Car: GTA
You can add an cable like the drag racers do for the front end & the axle droop limit cables the 4x4 guys have done for years.
Old Oct 18, 2011 | 04:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have seen the lower shock mount lowered, that will make the rear drop more when you raise the car though.
Old Oct 18, 2011 | 05:23 PM
87350IROC's Avatar
Car: 87' IROC
Agreed. However that just isn't as elegant as a properly sized shock.
Old Oct 18, 2011 | 05:25 PM
87350IROC's Avatar
Car: 87' IROC
Yeah, although the shock mount already sits pretty low. Spohn told me about a year ago they were working on a lower shock relocation. I have not seen anything yet.
The relocation should actually make the axle drop less, as the shock is more extended and closer to fully extended at all times.
Old Oct 18, 2011 | 06:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
The relocation should actually make the axle drop less, .
you are correct! i had a brain fart
Old Oct 18, 2011 | 10:45 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No need for shorter shocks. The bumpstop is the bottoming limit, not the shock.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
draco
Oct 4, 2015 09:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
