Factory Vs Eibach springs - question! help please...
Old Oct 21, 2011 | 12:00 AM
leedavidalan's Avatar
Hey fellas I have an 89 Iroc. First and foremost I don't know if it was previously lowered. A couple days ago we changed the rear springs, which I'll assume were factory, and when compared to the 1" lowering Eibach springs which I purchased, the Eibachs were actually taller!! Is this common? Perhaps the Eibachs are taller but have less resistance?
Also, how long before the new springs actually settle? We'll will install the front springs as well, later next week.
Thanks guys....
Old Oct 21, 2011 | 12:51 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Factory Vs Eibach springs - question! help please...
Your springs were sagging from age, The springs will settle after a couple good bouncy rides.
Old Oct 21, 2011 | 12:53 AM
After how many miles would you say? 20? 50?
Old Oct 21, 2011 | 12:59 AM
Car: Camaro RS
Its not an exact science,
Old Oct 21, 2011 | 01:02 AM
I see. I have around 20 miles so far, and the rear height is pretty much the same. Hopefully it lowers more. Thanks.
Old Oct 21, 2011 | 01:26 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
they dont settle..they may re-position themselves into a niche but they dont "settle"
not sure why the new ones would be taller though..
are you running the isolator on your springs? (the rubber piece)
Old Oct 21, 2011 | 01:31 AM
Car: Camaro RS
I would take the isolator out and use some tubing or hose that will be and inch or so
Old Oct 21, 2011 | 07:34 AM
UMI Sales's Avatar
Hey there leedavidallan. A premium spring like your Eibach is designed to "not settle". As mentioned above, where it's at is where it's probably going to stay. Did you buy the equivalent springs for the front as a set?
Old Oct 21, 2011 | 01:16 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
thats what i did :thumbsuP; no hose though..
doesnt make any noise at all without it..im not running them in the front either
Old Nov 2, 2011 | 12:36 AM
thanks guys. i'll just try removing the isolators. So the front springs have isolators as well?
Old Nov 2, 2011 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, but totally unlike the rears in design. See the link below for a pic:
http://www.spohn.net/shop/1982-1992-...Isolators.html
JamesC
Old Nov 2, 2011 | 08:19 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Before my original rear springs came out, I measured them. The rear left was 1.5" shorter than stock height. Passenger side wasn't as bad (0.25").
The Eibachs are a 1" lowering spring. So had I gone Eibach, my ride height would have gone up on the left side and down on the right side. Leveling out the combined sides.
Long story short, old springs get shorter over time.
Old Nov 2, 2011 | 10:00 PM
Oh ok I see. Thanks guys!!
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
novaderrik
Aug 10, 2015 12:44 PM
