Aftermarket Suspension Setup's
Old Nov 28, 2011 | 11:47 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Who here has a full Aftermarket Suspension Setup???
Old Nov 29, 2011 | 07:56 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Aftermarket Suspension Setup's
Only thing things I don't have are upper strut mounts and Aarms for the front.
I havent seen any products that I like over the OEM stuff yet.
Old Nov 29, 2011 | 08:02 AM
Twin_Turbo's Avatar
I have on my 82 TA, tubular arms, k member, oni struts/ shocks, tubular rear lcas, aftermarket springs, lcarbs and to come a fays 2 and some &M caster plates
I have the same on my camaro but with stock front a arms and K member but setup w/ moog balloints and poly bushings. For the rest it's the same as above.
Old Nov 29, 2011 | 08:56 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
The only completly stock suspension pieces I have are the front A-arms. I'm running a BMR panhard rod, boxed stock arms (big improvement over unboxed), Founder Performance LCARB's, modified Spohn torque arm on custom built crossmember, Spohn K-member, and Spohn upper strut mounts.
Is there a specific question you had, or are you just wondering what everyone is running?
Old Nov 29, 2011 | 10:15 AM
Twin_Turbo's Avatar
How did you notice the improvement in the boxed arms?
Old Nov 29, 2011 | 11:50 AM
built91Z28's Avatar
A lot less wheelhop. I really wasn't expecting that much of a difference honestly as I'm a natural sceptic of just about everything till I see it. But it really did work great.
Old Nov 29, 2011 | 12:31 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I can definitely see your skepticism about tubular A-arms, I share it. However I am fairly uninformed when it comes to aftermarket upper strut mounts... what's your caveat with them?
Old Nov 29, 2011 | 12:56 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
My suspension is 100% aftermarket front and rear:
tubular k-member
tubular arms
camber plates
strut tower brace
coil-over's
Koni's
wonder bar
spohn sway bars front and rear
spindle mod
bump steer kit
off-set tube lca's & relocation brkts
tubular torque arm
intrax springs
Bilstein 4611021's
panhard bar and relocator
Old Nov 29, 2011 | 12:59 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
I just put in new shocks struts and new bf goodwrench 235/60/15x8 all around. I have been looking around in the junkyard for some iroc/ws6 sway bars. Anything cheap I should be looking out for?
And I was wondering about strut mounts. I heard that the bushing can wear, I have seen some for $150 new, which isn't too bad. SFC would be nice, but I don't want to drop very much money on my suspension yet.
edit: Also I was looking for a wonderbar, still haven't seen one in the junkyards yet. I also put new rotors and pads on the front and looking for a 4th gen rear with disc/3.42's
Old Dec 19, 2011 | 11:27 PM
If anyone is running a Full Aftermarket Suspension Setup, I'd like to see it...
Maybe the Sales Department at UMI has a car that they have fully done. (I noticed they have been active in the Suspension/Chassis Forum)
I think it would be nice to see a thread with A Full Setup, Some Pictures, Thoughts/Feedback on each piece.
Old Dec 20, 2011 | 04:19 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
mine is pretty complete
WS6+ suspension
aggressive street alignment (vetrucks specs)
Kuhmo Ecsta Ast 245/50/16 tires 30psi
Spohn Front end rebuild kit with poly tie rods
UMI Adjustable Strut mounts
KYB GR-2 Front struts
KYB Gas-a-just rear shocks
Eibach Pro-kit lowering springs
Heater hose spring mod
36mm front sway bar with poly bushings
24mm rear sway bar with poly bushings
Stock painted A arms poly bushings and poly ball joints
new poly front and rear sway bar endlinks
Front K-member Braces
UMI Steering Brace
BMR Strut Tower brace
BMR weld in outer subframe connectors
Alstons weld in Inner subframe connectors
BMR non adjust Torque arm with poly bushing
Edelbrock On car Adjustable panhard bar poly bushings
J & M Street non adjust Lower Control Arms
Founder Performance lower Control arm relocation Brackets
its alot more stiff and rigid than stock thats for sure... almost feels like a go cart because i can feel EVERYTHING and i can feel the motor rumbling and its just a overall good feeling... no more broken tranny mounts thanks to the poly bushing... the only thing i want to add to my suspension is koni yellow on all four corners.....
Old Dec 20, 2011 | 05:56 PM
92 BBC Z's Avatar
Feel free to check out my album. I think that it might be to many pic's(atleast 10) to post the whole suspension.
Old Dec 20, 2011 | 08:05 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
My 84 is getting there......
BMR tublar A Arms
Koni Reds front/rear
Spohn Wonder Bar, Front end rebuild kit
Founders Strut Mounts
Eibach Pro Kit springs
UMI Adjustable Torque Arm w/ driveshaft loop
Hotchkis front sway bar
UMI rear sway bar
Spohn rear control arms and relocation brackets
Spohn adjustable panhard bar
I still have Spohn subframe connectors yet to be put on and am thinking about getting a strut tower brace in the near future.
Old Dec 20, 2011 | 08:30 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
all aftermarket front Suspension.. sphon K Member A arms coil overs Lakewood 90/10 struts. willwood brakes
all Aftermarket rear Suspension Wt jacks and springs Lakewood 50/50 shocks .Matco Billet LCA's. and Currie 9" housing. ajbl panrod bar
SSM Lift bars w/subframs (love them)
Old Dec 20, 2011 | 09:18 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Old Dec 20, 2011 | 09:22 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
I have more but you get the idea. all umi but K memeber when sphon( umi didnt have them yet
Old Dec 22, 2011 | 12:44 PM
UMI Sales's Avatar
Hey mo. Thanks for posting the pics of your UMI parts.
We have an IROC with all our parts on it but we've pretty much beaten it to death so it's not so picture worthy at the moment. Hammered cars for us help produce good products for you guys though, so it's worth it.
ramey
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
