Stock IROC or Eibach sway/stabiliser bars
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I've got a 1988 IROC, which has the best of the factory sway bars.
Would there be any benefit of from replacing these with the Eibach sway (stabiliser) bars?
The stock sway bars seem on ok condition, although the rubber insulators need to be replaced.
I have a set of Eibach Pro-kit Pro-kit lowering springs and apparently the Eibach sway bars are "tuned" to work with these.
Anyone here have experience with the Eibach stuff?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Stock IROC or Eibach sway/stabiliser bars
The is little reason to use aftermarket bars unless they offer a size not available stock. You would see benifits from new mount bushings and endlinks.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
^^^ Agree with the above.
Sway bars being "tuned" is a fancy way of advertising brand name. Sort of like saying AC Delco spark plugs are "tuned" for GM engines.
Some poly bushings and end links would make a nice improvement. Money well spent.
Transmission: T700
Thanks for the tips. I'll just get a set of poly urethane bushings.
Will put the money saved on sway bars towards a brake upgrade.
mustangman65_79
Aug 11, 2015 03:17 PM
