Add a cross member to help t-5 life????
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
I just think about this. Spohn offer a crossmember that relocate the tork arm off the transmission to cross member. Leaving the front crossbember and adding a crossmember to the tail of the transmission bolted to the tork arm would fix the problem that all t5 have??? flexy housing??? anybody did this???
From what i have read the T-5 are good its the body that is bad what about boxing the tranny too?
Re: Add a cross member to help t-5 life????
it may cause some vibration...but a prefer vibration thant blow tranny... a tranny swap is to much $$$ for me i pull 367whp and i am about to add 200shot nos.
Car: 1991 RS
Yes, by relocating the mount of the TA off the trans you relieve the stress that it sees. Helping it live a longer life.
what about my idea of adding a second crossmember attached to the tail of the tranny with tork arm?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the main case is the weak part, not the tail shaft, so a extra crossmember will prove little to nothing.
Gforce makes a upgraded main case for a few hundred bucks and its really the only way to "fix" this issue.
Car: 83Z28 HO
Transmission: G Force 5 speed
I bought one from UMI...not that I've had any issues, but it can only help.
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
jegs makes a torque arm that mounts to the tranny hump allowing for any transmission to be used. It is also claimed to give better 60 ft times. I run one with a wct5 and it improved the car considerably IMO
any pictures of thst main case???
and what internal beef up kit is better g-force or Astro?
Not sure what all this "add a crossmember" business is all about, since there's nowhere to "add" one, that it would fit.
A more commonsensical thing is to change to a crossmember and torque arm that hooks the TA directly to the xmember.
No it will not make any significant difference to the longevity of the trans.
Car: 83Z28 HO
http://www.umiperformance.com/catalo...ex&cPath=6_178
Looks like a great idea to take stress off the tail shaft of the trans which is why I got one - although it will do nothing about the other stresses that occur (like the input shaft bearing bore issue). Only the aftermarket case could address that.
Car: 86 Trans Am
There's no "adding" a crossmember, but replacing one...it's a torque arm relocation bracket like this:
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
The flaw is in the case. Engine torque is transmitted through the gear shafts causing the case to flex, allowing the gears to move causing misalignment, which leads to broken cases and gears. The case material, gussets and quality are the problem. Adding outside support will not help, creating a quality case will.
Car: 83Z28 HO
Ahhhh...OK. Well, I don't see how that would work. Maybe I've been lucky, or I just don't abuse mine enough...but it's held up really well, even with the blower installed. I jet bought a relocation bracket for more peace of mind I guess. Plus it's a stupid design IMO to attach the TQ arm to a trans tail shaft in the first place.
Car: 89 iroc
Transmission: wct5
another thing that helped me was a steel retainer plate from 5speeds.com. it makes the bottom end of the t5 a bit stronger for only $70 after shipping. It still doesn't save your synchro's from missed shifts,but it does make the factory case stronger with 4-6in lbs back lash. I'm not speaking with authority,just personal experience.
Car: 89 iroc
Transmission: wct5
and I run the FP out out of it. I have missed shifts and yes I've had to change synchro,s on that gear, but never hurt the case or cluster gear with over 400ft lbs of trq...knock on wood
Linson
Sep 21, 2015 01:08 PM
