4th gen steering column
Old Jan 2, 2012 | 07:47 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
There isn't much solid info on the boards regarding swapping in a 4th gen column. The column bolts up just fine, and all the connectors are the same. The major difference is the shaft sticks out further at the firewall than a 3rd gen and is 90* off. To compensate for this you can install an astro van steering shaft which is also 90* off. Direct bolt in no modification required. I used one off a 98 with no steering damper if it makes a difference. So in case anyone was wondering, now you know!
Old Jan 12, 2012 | 07:52 PM
90_383's Avatar
Car: 87 vert
Engine: 355
Transmission: wc t5
Axle/Gears: 4th gen 373 posi
Re: 4th gen steering column
nice ,got pics ?, just started stripping my 94 firebird to do an everything swap
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
