will this rear sway bar work for me.
Old Feb 1, 2012 | 01:38 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
OK so Im confused about something. I have a 373 rear end in my 91 formula. will a normal sway bar for a 91 formula work with this rear end. I wanted to ordor from TDS part no 202270 its the 24MM rear sway bar. Do i need a diffrent sway bar because I have a 373?
Old Feb 1, 2012 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: will this rear sway bar work for me.
Yes (the front and rear are matched at the factory).
Check as you may already have a 24 mm bar.
No.
JamesC
Old Feb 1, 2012 | 10:20 AM
Car: 91 formula
thanks.
Old Feb 1, 2012 | 07:19 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Just to reiterate if you didn't understand the whole picture - the front and rear work together. Make sure you pair them together correctly or you're going to see some negative handling changes. Lon @ TDS will take good care of you. He's well versed with suspension components.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
z28addict8490
Aug 7, 2015 08:48 PM
