rear end choice????????????????
Subscribe
Feb 14, 2012 | 09:20 PM
I can buy a ford 8.8 65" width from expedition with disc brakes already there or 9" for same price but has drum and is 63 3/4 wide. Anybody have any good suggestions here?
Reply 0
Feb 14, 2012 | 10:04 PM
Re: rear end choice????????????????
Buy a direct bolt in aftermarket diff. Although it's possible to install some other diff, it's not cheap or easy. The torque arm suspension makes it very difficult to install a diff not designed for a third or fourth gen f-body.
Reply 0
Feb 15, 2012 | 07:28 AM
Quote: Buy a direct bolt in aftermarket diff. Although it's possible to install some other diff, it's not cheap or easy. The torque arm suspension makes it very difficult to install a diff not designed for a third or fourth gen f-body.
+1 on this suggestion.
We have Moser's here for test fitting suspension components and to have bracketry already done from them saves a lot of hassle.
ramey
Reply 0
Feb 15, 2012 | 11:44 AM
if they're ready to bolt in (already modded) either option is good. if they're just stock rears, not worth your time unless you're great at fabbing and welding.
i too though an 8.8 might be a good route to go cause they're cheap in stock form; getting them to work in a 3rd gen with the torque arm will break the bank....
Reply 0
Feb 15, 2012 | 02:08 PM
Quick Performance makes bolt-in 9 inch housing only (Brackets Installed) w/ Torque Arm Bracket - $645
Complete w/ Moser Axles, Axle Bearings, Studs, Retainers, & Torque Arm Bracket - $1145
Reply 0
Feb 15, 2012 | 04:01 PM
Im getting a member on here to build my 8.8 rear as its cheaper than going with a moser, quick performance, and so on. Plus a 8.8 you dont lose power as in a 9 inch. Just my 2cents tho
Reply 0
Feb 15, 2012 | 05:26 PM
The amount of power you lose through different diffs is so minimal, the only way you would see a difference is the small numbers from a chassis dyno. If one uses a couple more HP than another, you'll never notice it on the street even if you did a back to back comparison.
Reply 0
Feb 15, 2012 | 08:37 PM
Thanks everybody for opinions. I do have fab skills so I will use 8.8 rear axle
it is 65" wide which is close to what i want anyway
Reply 0
Feb 15, 2012 | 09:52 PM
Take lots of pictures of your fabrication and swap and start your own thread on how you do it.
Reply 0
Feb 16, 2012 | 09:28 PM
I will for sure post pics of it all when ever I get started. Lt1 383 is first on the list.
Reply 0
Subscribe
