small block to big block what coil springs
Old Feb 28, 2012 | 11:17 AM
Firemanmarco's Avatar
I am putting a big block in my 86 camaro. This is a race car the only thing i have left to do is replace the front coil springs does anyone know what spring I should use I beleive that I need to raise the front of the car and it was suggested that I use the the heaviest 6 cyl spring that they make does anyone know where I can get the springs that i need and how do I change them is it hard to do
Old Feb 28, 2012 | 05:43 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: small block to big block what coil springs
i would ask for a Mod to move this over to the suspension part of the boards.
Old Feb 28, 2012 | 06:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Firemanmarco, welcome to TGO.
RBob.
Old Feb 28, 2012 | 07:00 PM
Thanks Denn I will do that and thank you TGO. Could a mod please move this to a more appropriate board?
Thank you
Old Feb 28, 2012 | 07:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran V6 front springs in mine for years before finally installing some Moroso trick springs.
Old Feb 28, 2012 | 08:07 PM
Was yours a big block as well? What kind of springs do ask for from moroso
Old Feb 28, 2012 | 09:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
My car has had a BBC since 2001. I only raced with a SBC for 2 years.
I'm using the BBC trick springs but could probably use the SBC springs as my nose weight is roughly the same as a factory street car with a SBC. The car still sits low enough as I scrap the spoiler loading into the trailer.
Springs hold up the car to ride height. How much spring you need depends on how much weight it needs to support. A BBC is roughly 150 pounds heavier than a SBC. Install some aluminum heads and intake and it's closer to 50 pounds heavier. It's not like you're adding an extra 500 pounds to the car by swapping the engine.
Old Feb 29, 2012 | 05:48 AM
I never knew there was that little difference between a big and small block I always thought it was at least 200 hundred pounds.
My car with no motor in it seems to sit lower than I would think it should.
The previous owner had a small block in it and suggested that I put the heaviest 6 cyl. spring I could find. I know that when I picked the car up the ground effects drug going on and off the open trailer I was using and that was without a motor in it. This car is a former super stock GT car so I don't know if they would have lowered it for some reason or not. Do you have a part number for the springs you are using by chance?
Old Mar 9, 2013 | 08:04 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
::thread hijack::
What springs should I use in a stock Camaro that I plan to put BBC in to keep stock height and be used as a street car not a drag car?
I have a set of Moroso Trick Front Springs, Could i use those for normal driving or should those be used strictly for drag?
Old Mar 10, 2013 | 12:16 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the weight difference becomes even smaller when you factor in all the stuff that you remove when doing the swap- you will likely ditch 100 pounds of AC stuff as well as a bunch of wires, hoses, and other accessories when you swap the big block in... it's not inconceivable that the car winds up weighing about the same as when you started...
Old Mar 10, 2013 | 12:44 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
i have an 86 Iroc it had the tpi 305 it now has a Big block cast iron heads and i use teh original Iroc springs and you can't tell it had a big block it isn't any lower than stock height.
the big tires in the rear tho did lower the front alittle
Old Mar 10, 2013 | 10:10 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm surprised nobody posted Moog 5662s, though I'd try the 5664s because they should give better handling, especially with that much weight.
Old Aug 4, 2014 | 05:21 PM
88_are_s's Avatar
Car: 1982 Chevy Camaro Z28
Engine: LG4 (Carbed 305)
Transmission: T10 (4-speed stick)
Axle/Gears: Salvage yard rear
Looks like i can leave the stock springs
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
sreZ28
Aug 14, 2015 07:48 PM
TA8487
Aug 11, 2015 09:02 PM
