panhard bar - should bolts line up on install with rear in resting position?
Old Mar 3, 2012 | 01:27 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I am swapping in another 9 bolt into my 89 GTA. The last guy cut slots through where the panhard bar connects so I had plates welded in, and they made bolt holes for me.
So the rear is installed and when I line up the bar to where it connects to the axle, it's off like 1/2 inch or so. I can get the bolt through if I push hard on the axle toward the passenger side of the car.
Is this typical or is my bolt hole likely off?
thanks for any help,
-Dan
Old Mar 3, 2012 | 01:36 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: panhard bar - should bolts line up on install with rear in resting position?
Typical for it be be offset some & need a body/axle push to line up correctly. Nothing to worry about.
Old Mar 3, 2012 | 04:27 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Most are off a lil bit.
The best thing to do is get a adjustable panhard bar to center your rearend in the car.
Old Mar 3, 2012 | 05:21 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
FYI: you don't need to jack up the car or the rearend to install a PHR. You should be able to park the car on level ground and just crawl under there and install it.
Old May 24, 2012 | 12:14 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
After the PHR is installed, what's the easiest way ( other than have someone else do it) to install the LCAs? Not much access to a shop have almost every non-power ( or Amish lol) tools. Got 2 jack stands and a rolling hydraulic jack.
Is there any simple way? Or am I over thinking it?
I know do one at a time, just forgot ... do it unloaded or loaded?
Having my senior moment.
I guess In My case ... grey is the new blonde.
Old May 24, 2012 | 03:36 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
as long as you do them one at a time, shouldn't be anything special. just remove the two end bolts, remove arm, install one end with bolt and nut on loosely, swing into place and bolt in other end. tighten and move on to the other side.
Old May 25, 2012 | 11:37 AM
Ok thanks going to be done a week from sat on payday.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
