Safest way to install
Old Mar 5, 2012 | 04:50 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I dropped off my a arm an steering knuckle to get new ball joints an a arm poly bushings in. They will be finished in the morning an I will be reinstalling everything attached what is the safest way to keep the spring in while setting everything back in an retorquing all bolts
Old Mar 6, 2012 | 09:08 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: Safest way to install
I like to use a spring compressor (one that goes on the inside of the spring is the only thing that will work). You might need to space the bottom clamp up from the end of the threaded rod or alternatively, cut the rod some. I have found that the rod will hit the top of the spring pocket before the spring if you don't. Then jack up the A arm and pass your bolts through, and then torque.
Old Mar 6, 2012 | 08:37 PM
Engine: LR4 4.8
Are u talking about the spring compressor u can rent from Autozone that has a claw that sits below the spring pocket cause it's the only one I can rent from Autozone ???
Old Mar 7, 2012 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pic of the tool below. Be sure and use the pipe nipple. I believe Autozone rents the one pictured.
https://www.thirdgen.org/forums/susp...nt-spring.html
BTW, Spohn sells an A-arm bolt kit if you'd like new ones.
JamesC
Old Mar 7, 2012 | 02:12 PM
Engine: LR4 4.8
That is the one Autozone has also has the other to compress to the a arm an hold it down that way I'll just get the one from Autozone again an for bolts I'm getting a set from my local steel shop a set of grade 8 bolts with nylon bolts so they don't back out or come loose from vibration
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
