Koni yellow quetion
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Koni yellow quetion
I just received my new Koni yellows and the rears came with a mounting stud for the bottom mount that looks like it wound make contact with rear end.
Should I knock it out and use the stock mounting stud?
Has anyone come accross this before? Thanks in advance..Steve
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Koni yellow quetion
pic? if they are 3rd or 4th gen rear konis, they will work fine as they are.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Fit fine in my '91 TA. Easy in and out with no clearance problems. Just put them in 2 months ago.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You want the studs to contact the rear end.... otherwise what's the point?
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
stock has a bolt going through the rear and the shock. The konis should have a bolt pressed into the shocks. Just line it up and slide that puppy through the rear and crank her down. Be careful if you have LCARBs because when you push the stud through both holes you can mess up the threads a bit. I did on mine but still all good.
Engine: 5.7 TPI
Sorry to take so long in responding to what I found, I havn't been online for a while. And the answer is.....old age can s**k at times. I was looking at the factory studs which were off the rear backwards.
As stated by all those who responded..they fit just fine. Next time I'll wear my newly aqquired glasses. Thanks Everyone, Steve.
LT1Formula
Oct 8, 2015 08:34 PM
