Spohn front end rebuild kit, pre greased?
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Hoping someone sees this tonight and can answer it for me before I do my autox in the morning. Are the spohn front end rebuild kits pre greased? When I put it together there was grease visible in the grease fitting hole, I just don't know if it's only a tiny amount and I need to add more, or if it's enough and I don't need to add more.
Thanks!
Thanks!
Received 1,688 Likes
Re: Spohn front end rebuild kit, pre greased?
You need to grease them... there's enough in them to assemble them, and that's about it.
hectre13
12-11-2023 08:14 AM
Terrell351
06-13-2021 01:13 PM
82, body, end, fbody, front, gen, grease, kit, pst, rebuild, rebuilding, recommendations, spohn, suspension, trans
