Creaks and Groans Normal?
Old Mar 24, 2012 | 12:21 AM
Guest
Guest
Posts: n/a
Hey guys, I have a 92 z28 with 93,000 miles on it. The previous owner garage kept her and didn't drive her but hardly. I have driven her about another 1,000 miles since I got it and the suspension has softened up a bit, not as much creaking, but I fish tailed her a couple days ago and on the return swing I heard a popping on the left rear suspension(it was a left turn fishtail). When I turn into steep driveways or crank the wheels all the way in either direction the front suspension will give a little pop. I just want to know if this is normal for our cars and just thirdgen GM construction and twenty year old car noises or if something might be wrong with my suspension?
Old Mar 24, 2012 | 06:31 AM
Re: Creaks and Groans Normal?
Normal? for a car with most of its lfetime of use already consumed that's being abused besides, yes.
Correct? no.
Sounds like it's time for some renewal work before beating on the car so much.
Old Mar 24, 2012 | 11:22 AM
Guest
Guest
Posts: n/a
On what planet is one fishtail on a car under 100k miles abuse? I mention one fishtail and I am "beating on the car so much"? Really? I'll wait until I get advice from someone who likes to enjoy their cars.
Old Mar 24, 2012 | 12:55 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Hey Jayhawk,
There could be a number of things going on, and it's hard to diagnose without being able to observe the car myself.
That said, you might just need to get under the car with a grease gun and lube all of your grease fittings - Ball joints, and tie rod ends. While you are down there check for play in your steering components and wheel. Look at the base of the grease zerk on the balljoint to see how far it has sunken into the ball joint. If it has sunken in and is below flush, that's a sign your ball joint is worn out.
Unfortunately to grease the rear bushings you'll need to unbolt one end at a time and I suggest slathering some silicone grease on the friction surfaces. Of course, if the bushings are deteriorating, you'll know they need replacement.
With a car that's done as much sitting as yours, I am not surprised it's developed some creaks and pops.
Try the simple stuff first.
Old Mar 24, 2012 | 12:58 PM
davidj3594's Avatar
Don't be a jerk.he gave you some good advice.How about replacing ball joints,Struts and springs for a good start.You have to realize the car is 20 years old now and has outlived most cars it's age. so it has consumed most of it's intended lifetime of use.
Old Mar 24, 2012 | 01:53 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Jack the car up and take a look at things. Get your hands on the parts and see if they move like they arent supposed to.
I'd look at the swaybar endlinks 1st.
Fishtail the car all you want (safely) its yours. Just be ready to fix things
Old Mar 24, 2012 | 05:52 PM
Guest
Guest
Posts: n/a
I'll get under her and check the ball joint and lube everything. Suspension upgrades are on the way after I hit the modest 300hp mark.
Old Mar 24, 2012 | 08:01 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
If u plan on modding up to 300hp an tq I suggest u install Sfc soon just my two cents ull eventually twist the unibody frame up with all the fishtailing ull be doing
Old Mar 25, 2012 | 03:40 PM
Guest
Guest
Posts: n/a
I don't fishtail on a regular basis. I don't want to twist the frame and a mess my suspension up. I'm only going to install suspension upgrades for a smoother ride and to better put power to the road. I'm not gonna fishtail her
Old Mar 25, 2012 | 06:53 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
These cars are not made out of construction paper. They road raced em pretty much right off the showroom floor in Canada for years. I think you'll be ok.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
