Suspension advice
Old Mar 27, 2012 | 01:12 PM
Guest
Guest
Posts: n/a
Suspension advice
I know jack **** about suspension. What would be the first thing I would want to upgrade on my 92, front and rear. I don't want to lower her, just start making a smoother ride and put power more efficiently to the ground. Tired of my creaks and groans going into driveways, etc. What would be the cheapest/easiest thing to start with on my suspension? Thanks a million guys.
Old Mar 27, 2012 | 01:59 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Suspension advice
some koni yellow shocks/struts will give you the smoother ride
http://www.summitracing.com/parts/KON-30-1265SPT/
http://www.summitracing.com/parts/KON-8741-1030SPT/
Old Mar 27, 2012 | 02:33 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
My personal opinion (not to be taken as gospel)-
Prior to ANY suspension changes, identify and fix ALL problems with pivots and joints FIRST, such as:
  • Ball joints
  • Tie rod ends
  • Pitman arms
  • Idler arms
  • Strut mounts
  • Steering joints
  • Sway bar links and bushings
If your struts and shocks need to be replaced (leaking or really weak/bouncy), replace them. If they are even reasonably good, hold off one step.
Now, replace the main suspension bushings if you haven't already. I'm partial to poly, but new rubber may be preferable in the rear LCAs. I'm considering going to Del-sphere in the rear.
Once that's done, struts are next. Go with the best you can afford. In fact, go a notch better than that. The better struts will control suspension motion better, AND more consistently for a longer time.
(Personal note: two things I never skimp on are struts and brakes. Both can make all the difference in the world, and can also help you keep the car from becoming a really expensive pile of recently-replaced parts.)
Next, get a REAL alignment. There may be those that argue this, but if you spend most of your time alone, sit in the car while they do it. If they don't want you to, that's a good sign to go somewhere else. I'm sure you can find specs on here somewhere, but on a "daily driver" I'd go on the high end for caster (as much positive as you can get within spec and adjustment and stay EVEN side to side), a little negative on the camber up front, and I maybe SLIGHT total toe-in.
Those things are not the cheapest to do (just bought a Moog idler arm to the tune of $70 and I get wholesale), but they are worthwhile. The creaks and groans are *probably* coming from overly worn pivots in various places. Once you firm everything up, you might be surprised at how well the car does. Oh, and if you decide to take any kind of break in the process, get it aligned. If you're going to keep swapping stuff, chunk it out, but don't try to evaluate changes without at least a rudimentary alignment.
That's probably a LOT more than you wanted, but that's my thoughts.
Old Mar 27, 2012 | 07:24 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Subframe commectors will help with the creaks and groans when the chassis flexes over driveways. Made the biiggest difference on my car.
Old Mar 27, 2012 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by jayhawk
I know jack about suspension.
For general info you might peruse the suspension stickies.
JamesC
Old Mar 28, 2012 | 11:31 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
i always forget about those yeah dude check those out and let us know if you have further questions
Old Apr 1, 2012 | 05:06 PM
Guest
Guest
Posts: n/a
I checked out the suspension boards. Its a foreign language to me.
Old Apr 1, 2012 | 10:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
what questions do you have after reading?
Old Apr 6, 2012 | 03:54 PM
Guest
Guest
Posts: n/a
What is a suspension bushing? What are subframe connectors? What are stuts? Basically, the only thing I know are shocks.
Old Apr 6, 2012 | 04:04 PM
JamesC's Avatar
For a full explanation of suspension parts as well as pics, please peruse the stickies at the top of the page.
JamesC
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
