rear spring helpers?
Old Mar 30, 2012 | 08:14 AM
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
I was thinking about adding a set to my Camaro. Wondering if anyone has done this & how it worked out? I wanted to stiffen up my coils to prevent my fender from hitting my tires.
Old Mar 30, 2012 | 08:55 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rear spring helpers?
If your fenders are hitting at slow speeds, your springs and/or shocks are worn & need replacing. If they are hitting at higher speeds? They can still be worn & start by slowing down. Or you could have wrong tires on like too tall (truck tires).
Don't put band-aides on by getting those little helpers, just do it right the first time. Those things don't stiffen springs, they just change the height.
Old Mar 30, 2012 | 06:36 PM
Altogether bad idea.
AT LEAST half as much money as DOING IT RIGHT (replacing the springs), and TWICE as much work.
Old Mar 30, 2012 | 06:50 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
I know the rims back spacing are off. They rubbed when I flew over some RR tracks. They are shitty tracks & I knew that just wasn't thinking. I've seen some guys at the track that had big tires on and don't have problems. They must have super stiff springs or shocks.
Old Mar 30, 2012 | 07:20 PM
Car: GTA
I'd use wheel spacers before I used those things. Actually I'd just get different wheels before anything, but not the cheapest way.
Could consider a 1998+ 4th gen rear end. Not the cheapest but will upgrade both your brakes & center section. Depends on the wheel fit though.
Old Mar 30, 2012 | 10:22 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Could also just get some spring spacers for the rear... they have them on ebay. ranges from like 1.5 - 3"
Old Mar 31, 2012 | 08:24 AM
Car: GTA
What are the specs on what you have now? Any pics?
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
