Help! Car is dropped on passenger side
Car: 1985 IROC Z28
Engine: 355 aluminum heads, comp 294 magnum
Transmission: 700r4 with B&M Mega Shifter
Axle/Gears: Motive 4.10's
I have an 85 iroc. I was making a turn into a parking lot, the car dips down really bad. Drove it home and took a look at it. The car on the passenger side is about an inch lower. If you push down on the gender it does not move at all it's completely stiff. The other corners of the car can compress up and down normally. What would cause this? Broke strut, mount, spring? Haven't had it completely apart yet.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help! Car is dropped on passenger side
Most likely the spring broke and the car is sitting the bump stop. Could be other more serious issues, but sounds like a spring to me,
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
jack it up and remove the tire, the issue should be self explanatory then.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
