k member swap
Old Apr 7, 2012 | 11:48 PM
84TransAm383's Avatar
k member swap
any one have experience on one. Just wondering how long it may take and if i should look out for any issues. It will be the spohn performance one. Thanks for any input.
Old Apr 8, 2012 | 12:15 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: k member swap
Depends on what you have for tools and how complete the one your swapping in is... I have done them dropping the whole stock Assembly... 2 engine mount bolts... 6 bolts on the k... 2 bolts for the k supports... pop 2 outer tie rods off the spindle... (I never pulled the springs, but id recommended it if your worried or have never done this) unbolt the 2 strut on the top of the camber/caster plate... and unbolt the brake lines... wall-la i think this job could be done in less then 45mins if you are swamping out and in new stuff... if your swapping parts over its going to take longer... id say an average estimate is 2 to 3 to 5 hours tops for most people...
Old Apr 8, 2012 | 12:25 PM
Re: k member swap
sounds simple enough...the motor is also already out the car so it should be pretty easy to do...i most likely using the stock suspension for now until i get enough up for the new a arms and all
Old Apr 8, 2012 | 12:47 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: k member swap
I would wait until you could do the arms too, That way you can just swap over your springs and struts and just roll the new K-member and a arms into place.
Old Apr 8, 2012 | 08:41 PM
Re: k member swap
if the motor in the car does it make that much harder...i have a tripod so i can just lift the motor up a little bit rather then have a hoist in the way under the car. Waiting seems like a better idea to have it all new at once. Thanks for input
Old Apr 8, 2012 | 09:22 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: k member swap
Also, if you have the room, you could always pre-assemble everything to the K-member (motor, wheels, ect) and lower the car down onto it. Just another suggestion.
Old Apr 8, 2012 | 11:29 PM
Re: k member swap
yea...i dont think ill be able to pull that one off as much as i would like to. Im gonna hold off though now. It makes more sense to have it all ready to go. Thank you all
customblackbird
Aug 15, 2021 10:16 PM
lt1z350
Aug 28, 2015 05:57 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
