New control arms!
Old Apr 16, 2012 | 11:06 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
New control arms!
Just put a new set of rear control arms. Theyre supposed to twist to keep the tires in contact with the road. It uses "Poly ball" 3 piece bushings. Didn't get to drive it too much because of traffic but it should work, What do you guys think?
Old Apr 19, 2012 | 03:53 PM
Engine: All 5.7's
Re: New control arms!
I guess no one has tried them yet? They are made by J&M.
Old Apr 19, 2012 | 04:10 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Wow those are neat haven't seen them before.
Old Apr 26, 2012 | 08:42 AM
blunierdr's Avatar
Car: 87 Trans Am GTA
Engine: Vortec Stealth Rammed L98
I was considering getting the same style LCA from Founders Performance. How much did you give for those beautys? Founders wants like 109 and some change for theirs.
Attached Thumbnails New control arms!-swivel_joint_control_arm_red__48711_zoom.jpg   New control arms!-swivel_joint_apart__89752_zoom.jpg   New control arms!-swivel_joint__18597_zoom.jpg
Old Apr 26, 2012 | 11:13 AM
87350IROC's Avatar
Car: 87' IROC
Those aren't the same. Eagle223usa arms have the mono-ball joint on both sides. The ones you have pictured only have them on one side.
Old Apr 26, 2012 | 04:00 PM
blunierdr's Avatar
Yes you are right, these LCA's are not identical to his. I noticed that a little late but the general concept is the same in both, preventing the LCA's from binding when the body rolls.
Old Apr 28, 2012 | 09:05 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
could just get the double rod ended LCAs and call it a day. I havent noticed much increase in road noise/vibrations from the rear suspension and mine is all rod ended UMI stuff.
Old Apr 29, 2012 | 01:47 AM
Engine: All 5.7's
I didn't want to go with Hiem joints because the streets here suck!
Hotrodboba400
Dec 10, 2019 07:07 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
