Anybody running the QA1 Stut tower brace?
Old Jan 22, 2012 | 12:49 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Got the April issue of High Performance Pontiac in the mail and in the back there is a small ad for the QA1 Strut tower brace for third gens. I am not sure if this is something new offered by them, but I haven't heard of this company making these before. They seem to be a slightly different design in that the mounts for the strut towers mount horizontally somehow (Atleast thats what it looks like in the picture in the magazine).
http://www.qa1.net/qa1_motorsports/d...er-braces.html
Any installed pics?
Old Jan 22, 2012 | 01:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Anybody running the QA1 Stut tower brace?
Oddly, 5227 was the part number for Edlebrock's verson, which you can see/compare at Summit (EDL-5227).
EDIT: The latter is installed on my IROC. A pic can be seen in my vbGarage (icon next to my online status).
JamesC
Old Jan 22, 2012 | 01:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
from what i gather QA1 bought edlbrocks designs for the stb's, hence the similar (exact) looks
Old Jan 22, 2012 | 03:44 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Anybody running the QA1 Strut tower brace?
They did. I made a thread about this. QA1 owns all of Edelbrock's suspension rights as of a few months ago and they finally made the transition.. hense the exact same design and part numbers.
Old Jan 24, 2012 | 12:54 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
They look like they tweaked the design slightly on the TBI version. Does anyone know if the firewall bars are still bolted on rather than welded for the TPI version?
Old Jan 27, 2012 | 11:31 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I hope it fits like the Edelbrocks i have seen. After calling umpteen places all
over the country i was unable to find an Edelbrock anywhere so, i ordered one
of these QA1 5227.
Old Feb 18, 2012 | 09:08 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Just got an email from Summit. My order for the QA1 STB has
been backorder delayed for the second time. Expected arrival
at Summit is 3-4-12. grrrrrrrrr!!!!!!
Old Feb 29, 2012 | 09:20 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Finally received the QA1 STB. It looks identical to the Edelbrock part. Just like
the Edelbrock, the support braces on the ends are wide and hard to fit on the
towers. My plan is to make some plates 'spacers' to set the braces on. This will
allow me to move the braces back a little 'over the strut bushing' so the bolt
holes for the braces are not so close to the strut tower edge. The braces will
overlap the strut bushing a little. I will have to replace my wiper motor. My 82
came with the old school analog wiper motor pump combo. The pump is in the
way of the STB. I found a newer style digital wiper motor with the newer
'smaller' pump built in which faces down so it is not in the way. Now i just need
to do a 4th gen washer and coolant bottle conversion... heh
Here's a mockup pic of the STB.
Old Feb 29, 2012 | 09:28 PM
Sweet man! It looks great, but you're right, it's really just the edelbrock STB with a different sticker on it. Though truthfully I would rather have something not branded under edelbrock on my trans am so it works out, lol.
I will eventually order one of these for my t/a but I gotta get it back on the road before I start modding suspension!
Old Feb 29, 2012 | 09:47 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Yea and. well this sticker is not even centered so it is coming off anyway.
Looking forward to you continuing your project.
Old Mar 4, 2012 | 08:39 AM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
The sticker is prolly centered its the motor and everything is offset to the passenger side of the car.
Old Apr 29, 2012 | 10:59 AM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
I finally got the STB installed. I had to make a couple of shims
to raise the STB mounts on the strut tower so they clear the
strut mounts. This is needed because the STB mount overlaps
the strut mount. There is really very little room to align the STB
brackets where the bolts aren't right on the edge of the tower.
My car was already VERY stiff with SFC, wonder bar, fresh
springs and, Adjustable KYB's so it was hard to notice any diff.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
NBrehm
Aug 5, 2015 07:57 PM
