help with front suspension rebuild
Old May 11, 2012 | 08:12 AM
RedLS1Iroc's Avatar
Car: 87 IROC-Z
Well i have already taken apart all of the front linkage and im ready to go back in with the new parts....my question is how far do the parts excluding the ball joints need to pressed...i have a ball joint press that will do the job thanks for the help
Old May 11, 2012 | 08:27 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: help with front suspension rebuild
What parts in particular are you referring to? The only other parts that need pressing are the a-arm bushings. All other stuff is bolted up. Just make sure you use the correct torque specs.
Old May 11, 2012 | 08:56 AM
RedLS1Iroc's Avatar
Car: 87 IROC-Z
ok thanks i was talking about the tie rods ends, idler arm and center link..do you happen to know the torque specs or where they can found
Old May 11, 2012 | 09:15 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Just did mine. LMK if you still need the info I have an 88 Firebird service manual with the info. Note the tie rod clamps have to be pinched tight in a certain way with the clamp openings away from the sleeve openings. Compare to what you took off.
Old May 12, 2012 | 05:16 AM
RedLS1Iroc's Avatar
Car: 87 IROC-Z
thx talltim, torque info would be greatly appreciated:ball joints, inner/outer tie rod ends,idler arm pitman arm,sleeve clamps and sway bar end links
Old May 12, 2012 | 07:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by RedLS1Iroc
pitman arm
Since the pitman arm is a non-wear item, there's no need to replace it--unless, of course, it's been damaged. Aside from a bone yard, you probably couldn't lay hands on one anyway.
JamesC
Old May 12, 2012 | 09:57 AM
RedLS1Iroc's Avatar
Car: 87 IROC-Z
ya im not replacing the pitman arm i was just referring to the torque from the pitman arm to the center link
Old May 12, 2012 | 10:59 AM
TallTim's Avatar
Hey guys this link has the 88 Firebird manual that has the torque info and lots more!
Link still seems to work if not LMK.
https://www.thirdgen.org/forums/tech...ce-manual.html
Old May 12, 2012 | 04:44 PM
Copchaser's Avatar
torque specs: Got them from the Haynes Manual. I have them memorized as I just came out of the garage finishing mine up..
Center Link to Inner tie Rod End 50 ft lbs.
Spindle to Outer Tie Rod End 35 ft lbs
Center Link to Inner Tie Rod End 50 ft lbs... per Moog
Old May 12, 2012 | 07:06 PM
RedLS1Iroc's Avatar
Car: 87 IROC-Z
Thanks a million going to put it together this evening
customblackbird
Aug 15, 2021 10:16 PM
fbirdroller
Sep 2, 2015 10:27 PM
cam-mike
Aug 24, 2015 07:23 AM
