Does/should adding SFCs alter alignment?
Old May 15, 2012 | 12:24 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I just had some UMI sfcs welded in on my car. Can definitely tell the difference in how the car feels, especially over curbs! However, ever since I got the car back, the steering wheel has been off center to the right. I had it so the wheel was mostly straight before (need to tighten up the box) but is about 1/3 turn to the right now.
Was just wondering if this is normal, or did the shop that welded it in goof up somehow? I did a search, didn't really find anything directly related, maybe I missed something, but nothing came up for me.
Old May 15, 2012 | 05:00 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: Does/should adding SFCs alter alignment?
the car needs to have all 4 wheels on the ground and level when installing SFC according to the instructions. In my experience when adjusting the gearbox, it's only a short term fix because the gearbox is already wore out.
Old May 15, 2012 | 06:05 PM
V6canvas's Avatar
Engine: Stock LS1
I know that I should be on the ground (our a drive on hoist), and -assuming- it was, would the alignment change? I don't think it should, but I wasn't sure since this is a first for me.
Would you recommend a new box then? From where?
Old May 15, 2012 | 11:19 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
AutoZone (in Ohio anyway) sell a quick ratio remanufactured box for around $120. can't remember if the warranty is 1yr or lifetime.
Old May 16, 2012 | 06:43 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Welding the sfc in incorrectly will screw up your alignment. Its completing the frame and if done wrong it will have tweaked the full frame.
Old May 16, 2012 | 07:32 AM
UMI Sales's Avatar
Thanks for choosing UMI for your car. We appreciate it.
In most cases the SFC's won't change the steering wheel indexing if the SFC's were welded in with the suspension fully loaded. Basically the SFC's just keep the chassis of the car in place during operation instead of allowing it to flex.
ramey
Old May 16, 2012 | 08:34 AM
V6canvas's Avatar
Engine: Stock LS1
ramey
Thanks for the reply, that's what I thought should be the case. But I just wanted to be sure.
Ed1LE
Sep 30, 2018 09:14 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
