Uneven ride height
Old May 19, 2012 | 10:26 PM
Yager90IROC's Avatar
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Uneven ride height
Just had new springs and struts put in on all four corners.
Moog 5662 and 5665 with KYB gr2 and Gas-a-just.
But noticed my car sits higher in the front on the drivers side.
After talking to the mechanic who did the work (didn't have time to do it myself ) I realized he may not have indexed the springs properly ( he said they just drop right in, no particular spot for them )
Just had a look under my car and neither spring is indexed properly, both have the ends in random locations.
I did notice that the passenger side (the lower side) was sitting a lot closer to the two holes than the drivers side( the higher side). Could this cause uneven ride height, or should both sides be level since they are both indexed improperly
Either way I have to go back to the shop Monday. Just wondering if this was the cause of the uneven height.
Thanks,
Mike
Old May 19, 2012 | 11:19 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Uneven ride height
holes really have nothing to do with the indexing ive found..you just spin the springs until theyre at there flatest point and it should be good..
Old May 20, 2012 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd have the springs indexed properly, which eliminates all the guesswork.
JamesC
Old May 20, 2012 | 01:06 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
JamesC
Agreed...I just did mine, and even my cheap Haynes manual says the lower end of the spring should end up between the two drain holes in the lower control arm. Once I get my car on the ground, I'll know whether or not it's sitting right.
Doesn't say anything about indexing the rear springs however....
Old May 20, 2012 | 01:17 PM
JamesC's Avatar
Nope, no indexing on the rear (although the spring should sit in the isolator correctly if you're using an isolator).
JamesC
Old May 21, 2012 | 10:49 PM
Engine: Stock L98
Ok I had the shop index the springs ( covering one hole and sitting before the other) and put in new isolators, but now the car is even higher. I know new isolators will make it sit higher, but I don't think it would have done this much. The car is still uneven by about half an inch as well. Any ideas?
DRIVERS SIDE:
Before
After
PASSENGER SIDE
Old May 22, 2012 | 12:36 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
mhmmm....
Old May 22, 2012 | 06:30 AM
JamesC's Avatar
Correct springs? Are they sitting correctly in the upper pockets? Have you driven the car? Are the isolators like the ones below--which won't raise the car to any significant height:
http://www.spohn.net/shop/1982-1992-...Isolators.html
JamesC
Old May 22, 2012 | 12:52 PM
Engine: Stock L98
Moog 5662.
How do I check to make sure they are sitting correctly in the upper pockets?
I've driven the car about 30 miles.
Yeah they looked just like that.
I did notice that the moog springs didn't have a flat end, is this normal? Maybe I had the wrong spring in the box (the box said 5662)
Old May 22, 2012 | 01:23 PM
JamesC's Avatar
A look would tell you if something is awry. That both springs aren't sitting correctly in the upper pocket would be surprising. I'd guess that there's something amiss with the springs themselves.
Check post #5 of the link below for pics/info about the flat end:
https://www.thirdgen.org/forums/susp...nsion-how.html
JamesC
Old May 22, 2012 | 02:03 PM
Engine: Stock L98
I saw the picture, when I looked at the springs both ends looked like the bottom of the spring in the picture.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
87v6Bird
Jul 1, 2018 04:12 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Oct 5, 2015 06:23 PM
Vincent135
Sep 28, 2015 10:50 PM
