loose steering column cover
Old May 30, 2012 | 03:19 AM
AlexeitheWolf's Avatar
So I had the problem with a wobbly steering column but before i could fix it I was driving and heard a snap. then the cover behind the steering wheel that houses the ignition switch and turn signal lever started rotating around the column. anyone know how its all held in place and what the solution might be?
Old May 30, 2012 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: loose steering column cover
Welcome to TGO, AlexeitheWolf.
Check the How-to sticky at the top of the page for pics and info. BTW, there are many questions that haven't been asked and answered to site, so a search is generally a good idea.
JamesC
Old May 30, 2012 | 01:18 PM
I did but the only thing i seem to find is how to fix a wobbly steering wheel not the sleeve behind it
Old May 30, 2012 | 03:15 PM
JamesC's Avatar
I would have thought the pics and tear down would have been beneficial. Are you discussing the lock plate cover (plastic), held in place with three plastic tabs, or the lock plate itself, held in place with a snap ring? Check steering column exploded views (PDF's) in the following link for more possible help:
https://www.thirdgen.org/forums/susp...ce-manual.html
Best of luck with your project.
JamesC
Old May 31, 2012 | 02:52 PM
So i fixed the wobble and put it back together but now the key is really stiff/ hard to turn and it sometimes it makes a cracking/snapping sound when i turn it. any ideas what that might be?
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
