KYB GR2 Struts don't seem to fit spindle correctly
Old Jun 7, 2012 | 12:12 PM
Wifes87SC's Avatar
Hello,
I have a 1987 Camaro Sport that was a V6 car when I started. I have swapped the entire drive line from a 1991 Firebird Formula 350 with WS6 suspension. I installed a set of KYB GR2 struts, but they seem to be too wide by 3/32" when mounting to spindle, has anyone ever seen this before?
Old Jun 8, 2012 | 08:09 AM
mstacy1's Avatar
Re: KYB GR2 Struts don't seem to fit spindle correctly
I just got my GR-2's yesterday and they are a bit wider at the mounting point than the spindle. The old struts look like they pulled in once torqued. I think they will be fine once tightened. Sounds like we are doing similar projects. I'm swapping out a v6 auto in a 92 convertible with a 305 tpi 5 speed from a 91 Formula. Just curious, which front springs are you using. I have a set of MOOG 5610's I going to use. Trying to get some feedback in another post but I guess no one else is using them.
Old Jun 8, 2012 | 08:54 AM
Wifes87SC's Avatar
Thanks for the reply, but I did tighten them and the alignment shop said there is too much play to align car correctly. I'm using the stock ws6 springs so I can't offer any input on the 5610's. Let me know if you can get the car aligned correctly.
Old Jun 8, 2012 | 09:44 AM
mstacy1's Avatar
Interesting. Is the shop indicating the issue is with the gap or play in other components? When you torqued them, did the gap close?
Old Jun 8, 2012 | 09:59 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Those torque to around 150 ft lbs (some charts show higher). Torqued correctly it should tighten up the 'ears' to the spindle. A set I had were the same way.
Old Jun 8, 2012 | 03:38 PM
Wifes87SC's Avatar
The shop thought it was the struts as the entire front end is new. I will take NAF advice and torque them to 150 ft lbs and see what happens.
Thanks NAF I'll let you know if that does the trick.
Old Jun 12, 2012 | 08:39 AM
Wifes87SC's Avatar
Well 150 ft lbs did the trick, the front end shop was able to align the car over the weekend. Thanks again NAF
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Vintageracer
Aug 11, 2015 08:13 PM
