White plastic ring with Koni Yellow struts?
Old Jun 21, 2012 | 08:37 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Does it do anything? The instructions aren't all that clear and the old struts didn't appear to have that ring. Do I need it or not? Where's it go?
Old Jun 21, 2012 | 10:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: White plastic ring with Koni Yellow struts?
I don't know what they are for, but my thought is that they are a hard cushion to prevent the strut from bottoming out all tyhe way and causing serious damage to the strut
Old Jun 21, 2012 | 11:23 PM
87350IROC's Avatar
Car: 87' IROC
They fit snugly on the strut shaft right? If so I suspect they are suspension travel indicators. I use my tube mounted bump stops for the same reason.
Old Jun 22, 2012 | 01:33 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
They don't fit tight at all, really sloppy.
Old Jun 22, 2012 | 01:58 AM
87350IROC's Avatar
Car: 87' IROC
Strange. I remember seeing them. But never put them on as I didn't see a purpose.
Engine: LG4
Right. I figured they'd rattle like all hell, so if they don't do anything important I'll keep them in with my other spare parts.
Old Jun 22, 2012 | 09:35 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I left mine on, wasn't exactly sure what they were for, but I figured they wouldn't hurt anything. They may rattle around, but you cannot hear them.
Old Jun 22, 2012 | 11:23 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
They are called packers. They are used to space out a shaft mounted bump stop or in extreme cases, prevent the damper from bottoming out internally.
J-money
Jan 4, 2019 09:45 AM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
