rear lower control arm questions
Car: 86 IROC
Engine: 355 Stealth Ram
i have a completely stock 86 iroc im trying to make road worthy again and i see founders performance lower control arm relocation brackets and control arms and panhard bar. Would i be wise to make these upgrades?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rear lower control arm questions
if you are just trying to make the car road worthy, there are better things to do first. Tires, shocks struts, brakes, and balljoints. You will see more of an inprovement in the car with those pieces in good working order. They you can think about shiny parts.
Transmission: A4
Dont worry about those parts right now. Get the car running the way it should be running and then you can go and change things out. Then you will be able to see the difference that those parts make on the handling of your car.
Car: 86 IROC
dont get me wrong the car runs there are just minor things i need tires and i figured if the tires are off the car why not upgrade the rear alittle cause im sure it needs to be done.
Car: 86 Trans Am
Fwiw, don't bother with rear suspension parts with poly bushings, they are actually a bit oof a downgrade from stock and introduce significant bind into the suspension that the stock rubber bushings don't.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
That's fine, but what about the condition of the shocs and struts? The steering linkages and the front bal joints? If they have not been serviced in the time you have owned the car, chances are they need attention.
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
They really help the car handle better. Your going from a bent piece of metal to a solid tube. If you can find a good deal on them go for it. I got my LCA's and Panhard for $150 for a non adjustable set.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
