What are all the parts to steering linkage?
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
So I was looking to change out my steering linkage. I did a search and seems that everyone prefers to go Moog. So I will do the same. Now I guess Moog doesn't sell it as a set, so I think I have to purchase each part individually. Unless anyone has a link to a full set for sale. The only other full set I can find is PST on ebay. Any other brands out there that are fairly good? I figure Moog is top of the line and I guess very expensive too. So I'm kind of working on a budget. If worse comes to worst I'll just get Moog.
Engine: 5.7L TPI
Axle/Gears: 3.47
Re: What are all the parts to steering linkage?
Ok I copied off of the ebay of PST of what parts I need.These are all Moog parts 2 Idler Arms Part#k6249 (Are they universal to both sides? Do I need to order a left and right side because on Advance auto parts only has 1 choice) 2 Tie rod ends inner Part# ES2226RL (same question as the idler arms?) 2 Tie rod ends outer Part# ES2227RL (again universal?) Center Link Part# DS1049 and 2 Adjusting Sleeves (same question) With coupons and everything it comes out to roughly 350$ for all of it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's only 1 idler arm, on the passenger side. The driver's side has a pitman arm on the steering box.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
That got me thinking for a minute, there is only one lol.
Engine: 5.7L TPI
Axle/Gears: 3.47
Engine: 383 Carb
Transmission: 4L60
It's not necessary to change any of it, unless it's worn out.
Engine: 454-350
I don't think you need to change the pit-man arm, I never have.
Engine: 383 Carb
Transmission: 4L60
The pitman arm is just a dumb lump of cast iron, there's no joints in it.
Engine: 5.7L TPI
Axle/Gears: 3.47
My steering is very loose, this is why I want to change it. It still has the original one. So what else might not need changing? What are the important ones to change?
Engine: 5.7L TPI
Axle/Gears: 3.47
Quick question hope someone can answer ASAP so I can order for tomorrow. I ordered all the parts above. Do I need to purchase ball joints too??? If so I just need two lower ball joints?
Engine: 5.7L TPI
Axle/Gears: 3.47
If someone can correct me. I think the new tie rods come with the ball joints already?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
tie rods and ball joints are completly different and seperate parts . good luck .
Fronzizzle
Mar 18, 2019 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
