air lift spring helpers with cut springs
Car: 88 firebird convertible
Engine: 305 tbi v8
hey guys, so i was thinking of cutting a couple coils to kill the gap on my bird, but was wondering, if anyone has airsprings/ spring helpers on their car ? the reason i ask is cuz i wanted to know how tall they were at their lowest setting. i had something like this on a truck i had lowered and it ended up raising it to stock height pretty much at its lowest point.
basically want it just in case i wanna raise the @ss if necessary.. lmk thanks
Re: air lift spring helpers with cut springs
Air shocks aren't recommended or a good idea on 3rd gens. The mounts are not designed to take the stress. In stock form the upper mount can/will tear from normal use.
Air bags on the other hand could work. A small diameter bag inside the springs could lift the rear back to stock height. Ride quality would suffer though.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Air bags should not be use to raise the rear but ensure the rear does not go any further down.
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
