problem with torque arm n transmission
i have a 1991 camaro n it was a v6 car. Im putting a v8 in it n 350 turbo transmission.the 350 turbo doesn't have the bolt hole for the torque arm.i need to know how you would set it up.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: problem with torque arm n transmission
If you can fabricate you can make one that is attached to your transmission cross member.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Purchase an adjustable TQ arm from Jegs..... This unit bolts to the tunnel not the tranny..
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Spohn makes a great cross member mounted adjustable torque arm.
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
