Tie Rod replacement bolt/sleve
Old Sep 10, 2012 | 07:03 AM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Had to cut out the rear end upper tie rod bolt. The 3 bolts on the chasis came out good, but I need the replacement bolt and sleve for the other side and I cannot seem to find one. Someone post a link on where to get this please?
Old Sep 10, 2012 | 09:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Tie Rod replacement bolt/sleve
Originally Posted by Sidethumper
Had to cut out the rear end upper tie rod bolt. The 3 bolts on the chasis came out good, but....
Are you talking about the track bar brace (aka the panhard brace)?
JamesC
Old Sep 10, 2012 | 09:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I get mine from GM, pricey tho...
Old Sep 11, 2012 | 08:41 AM
JamesC
The bar/ brace above the panhard bar
Old Sep 11, 2012 | 02:44 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
UMI sells a replacement bar but I'm not sure it might actually relocate it as well. Maybe ask UMI to sell you only the bolts ?
Old Sep 11, 2012 | 03:47 PM
OK I got some pics here, this is the upper tie rod. Notice the top part of the bar there where I cut the sleeve out along with the rest of the bolt.... did I ruin this bar? because it looks like the sleeve is actually part of the bar itself
This is the bolt /sleeve that I cut out
This is the center piece... note all the rust between the bolt and the sleeve.
So now that I have inspected the end of the rod better it looks like that sleeve is part of the bar, and if so I think I have ruined the bar because I cut the enire center out???
Old Sep 11, 2012 | 04:31 PM
This is called an panhard bar support bracket. UMI sells one:
http://www.umiperformance.com/catalo...roducts_id=289
Although, this relocates it so don't buy it unless you want to relocate and understand some of the negative effects of doing this depending on your car. But the part in the picture is essentially what you're looking for except it relocates the PHB.
Old Sep 11, 2012 | 04:45 PM
Ok, so what kind of trouble/negative effects am I getting into by relocating the panhard bar? I like the idea of giving extra room in case I want to run 3inch exhaust
Old Sep 11, 2012 | 04:51 PM
It's complicated LOL. There are other threads that deal with this but it's mostly for exhaust but a 3" exhaust will fit without relocating that bar so it's not necessary for 3". It would affect handling and there might be some contact with the lower bar depending on how low you go with the car. My recommendation to you would be to find a good used upper panhard bar support piece (not bent and preferably not rusted) and re-install with new hardware and you're good to go.
Old Sep 11, 2012 | 05:07 PM
Im not planing on lowering the car at all, I am planing on putting in some other UMI products like the panhard itself and the control arms, The bracket would look good in there...??? also Im not going to be racing this car or flying around hard corners. After all the money Ive been sinking into this thing the most I will ever do is a hole shot every once in awile. Besides there is'nt a curvy road anywhere in this God forsaken state rofl.
With all this said If I do decide to get the UMI brace do you think I will be ok?
Old Sep 12, 2012 | 04:04 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
just get one off another F body in the junkyard... or get a piece of tubing the same size as the sleeve you cut out and weld it in place.
Old Sep 12, 2012 | 08:42 AM
This car sat in a garage for 12 years and I had to cut the bolts.... I would hate to see what one in a junkyard looks like.
Old Sep 12, 2012 | 09:39 AM
Maybe post an ad in the parts wanted section. I'm sure somebody is selling this piece? I just cleaned mine up and painted it with POR15 and it looks brand new. It's just a support piece and it doesn't do much other than support the PHB.
Old Sep 12, 2012 | 11:52 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
the umi part will work with your old part as well.
and it's for running 2.. 3" pipes over the rear end..if you want.
from there site:
"Relocation kit will work with the factory panhard bar and all aftermarket panhard bars."
my parts yard has 2 camaros in the yard at this time, the parts your looking for are only $8
Old Sep 12, 2012 | 01:28 PM
Thanks everyone for your input. I posted an ad for one.
Old Sep 17, 2012 | 10:12 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you know how to weld or know someone who ca you could make one in an hour or two dirt cheap. Plenty of threads and progress [ics of members doing suspension and cage pieces.
Old Sep 18, 2012 | 11:36 AM
I got a new bracket. Thanks everyone
Old Sep 18, 2012 | 11:44 AM
New ? Where did you find that? Or do you mean like one off another car?
Old Sep 18, 2012 | 06:34 PM
The guy I got my posi rear had one in real good shape. But it does look like new now with a fresh coat of chasis paint. I had to order the bolt from sphon. Actually I need to get two more for my new BMR panhard bar as well.
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
BBSDesigns
Aug 11, 2015 07:39 PM
