Spindle differences through the years?
Car: 87' IROC
Hi folks.
I just bought a spindle to play around with so I wouldn't have to do it on the spindles on my car.
These spindles will be modified in order to install a brake kit. This involves enlarging 2 of the 3 factory holes used to hold the stock rotor dust shield. The spindle I just acquired has different and smaller bosses where the top dust shield hole is. This is undesirable because the edge margin won't be very good once I enlarge the hole. Does anyone know which years have the larger boss like on the clean spindle?
The dirty spindle is supposedly from an '89 but I can't say for sure.
The clean spindle is from unknown year.
Thanks,
John
right click - view image for larger
Thanks,
John
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Spindle differences through the years?
Yeah, the old one looks like my old '89 spindle.
Brian
Brian
Car: 88' Iroc-Z
Engine: LQ9
90-92's have more meat around the holes. I think both of those are 89-older. GM wasn't exacting where they drilled the bosses, i've seen several that are right on the edge. ebmiller is the brake guru on tgo, he says if youre doing an ls1 brake upgrade that you will be fine with the older spindles. For anything bigger he does recommend the 90-92 spindles though.
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Hummm ... stock spindles on my '82 Z28, (later I modified them for C6 brakes)
~DaVe
~DaVe
Car: 87' IROC
Car: 87' IROC
Car: 87' IROC
Thanks Dave. Your picture is interesting b/c your boss looks bigger than my dirty one but smaller than the clean one. I suspect it is the same as the dirty one, just a slightly different angle.
Car: 87' IROC
I found the info I need. Sometimes Google works better than the thirdgen search. See this thread. Looks like you guys are right, the 90-92 are the ones with the bigger bosses.
https://www.thirdgen.org/forums/brak...ndles-1le.html
Car: 1986 Camaro
Engine: LS6
Transmission: Tick Stage 2 T56
Axle/Gears: Moser 12 Bolt
Does any one know where I can buy spindles? I take it that they don't make new ones any more and mine are wore out.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pick and pull down here in lakewood just got an 84 and 91 camaro in during the last week and a 83 firebird so I'll go and check it out to see what parts are left. I'll let you know.
I also know where there is a 90 camaro convertible in a wrecking yard that still had the spindles on it. If your interested in those I'll get you the name and number of the place.
Take care
Take care
1992rs/ss
16
Jan 28, 2016 09:58 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
