Spring Suggestions?
Old Oct 7, 2012 | 05:48 PM
ray1989's Avatar
Engine: 350 40 over
Spring Suggestions?
currently sitting on stock springs with kyb agx adjustable gas shocks and tubular rear lower control arms. looking for stiffer springs maybe go lower but not sure. by the end of the year i plan to have spohn sway bars and wonder bar to stiffen up the ride more.
btw plan to drift next spring/summer any help would be great for a good setup!
Old Oct 7, 2012 | 07:54 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Spring Suggestions?
Most people look at pro kit (handling) or sport kit (more lowering).
https://www.thirdgen.org/forums/susp...sportline.html
https://www.thirdgen.org/forums/susp...ort-lines.html
What ever you do don't go with the Drag Launch Kit it's not meant to handle.
Old Oct 7, 2012 | 10:17 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
I just put Eibach Sportlines on with the KYB gas-adjust shocks, they make it look really good but i havent driven it yet, cant wait!
Old Oct 8, 2012 | 09:53 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I had first bought the Summit brand 1" lowering springs but was unhappy with the handling and the ride height. I now run the Eibach Pro kit and am very satisfied with everything
Old Oct 8, 2012 | 03:09 PM
ray1989's Avatar
Engine: 350 40 over
I think i am going to either go with the pro kit or save up to get the ground control weight jack system.
Old Oct 27, 2012 | 07:32 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
I'm also looking at the Ground Control weight jacks. It's that or the Spohn coil over conversion kit. Still can't figure out if the coil over setup is worth the extra money.
Old Oct 27, 2012 | 07:38 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Ground Control is the way to go. I wasted so much $ on lowering springs over the years & never happy with either the ride, the vehicle height, or both. Now I have Ground Control weight Jacks & will never go back to standard springs.
And I'm not just saying that because I have a rear set for sell. I truly believe it.
https://www.thirdgen.org/forums/engi...d-control.html
Old Oct 27, 2012 | 08:58 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
If you plan to drift with the car, I would think you would want a little stiffer rear springs and rear sway bar than normal. Typically I would not suggest coil overs on the front because they limit you more on the width of the front tires, but, for drifting you don't need a real wide front tire (I wouldn't think, anyway. I'm not really into that, though) so it probably won't matter as much.
Old Oct 28, 2012 | 12:21 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
front coilovers are a solution to a problem that doesnt exist. For older cars it can be really nice because their suspensions just arent as good from the factory as ours are. Our strut towers werent designed to support the weight of the car, the coilovers limit tire width, and the main advantage is just easily adjustable ride (which can be done with regular weight jacks) and less weight up front which is good for the drag racing guys.
For people who only want to straight line on skinnies, coilovers are great. For people who watn street fighter corner carver daily drivers, stick with regular weight jacks.
You can make coilovers work really well, but I dont think you'd really see much if any real improvement over a properly set up weight jack + quality strut arrangement, and then youd have to be real careful about wheel offsets/widths with coilovers.
I'd love some weight jacks. You get the spring rate you want, and you use the weight jack to set ride height to get hte stance you want. It's the best of both worlds and you custom tailor it to your car.
Old Oct 28, 2012 | 07:37 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
This is probably one of the best answers I've herd. I'm having a hard time finding any information on the advantages and disadvantages of the two setups. I think the weight jacks are going to be on the list of parts for this winter.
Old Oct 29, 2012 | 11:00 AM
ray1989's Avatar
Engine: 350 40 over
yea i do like the idea of weight jacks. i just need to make sure they can be used when i do drift because i know that lowering springs cannot be used.
Old Oct 29, 2012 | 11:49 AM
Car: 1992 Camaro RS
Why cant lowering springs be used? I dont understand that logic at all. Lowering springs are simpler than weight jacks and function identical to stock sagging springs, just with a higher spring rate. Weight jacks add mechanical spacers in there.
This guy drifts and has weight jacks...
Old Oct 29, 2012 | 02:00 PM
ray1989's Avatar
Engine: 350 40 over
Im not sure thats just what the list of rules says haha
pjsparts
Oct 29, 2025 06:39 PM
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
sandman92084
Sep 12, 2015 10:27 PM
